#1156
#1157
| Post #406 on page 28 shows a very simple configuration.
#1158
Spence |
#1159
| thank you, Ender and Hoytedow. |
#1160
#1161
| Quote: Erich |
#1162
| Will do. I, too, was surprised by the low cost. You're right- other similar parts seem to cost about twice that. |
#1163
| weed eater engine conversion I have made small propulsion drives from several conversions but would a post hole borer not make an easy conversion and be robust and push a heavy boat well. The attachment shows the borer shaft turned end for end and stripped a bit. I did experiment with an auger drive and was happy with the end results. Some two stroke motors can have the ignition turned to give running in both rotations.
__________________ tomkane |
#1164
| I think 43 cc would work very well. I wish the airboat motor I threw together had been 43 cc. It would have performed better than the 25 cc I used. See page 41 this thread.
#1165
| The price is NZ dollar an equivalent outboard would be thousands of $
#1166
Mark |
#1167
| 45 cc does not equal 6.5 HP and the idea is that the auger screws its way through the mud providing propulsion ..you should always consider with these projects if a mouse can power your boat even when its wheel is geared down.... |
#1168
| The advantages I found with the auger prop was that it would give thrust in sand mud weeds and even with a lot of weeds around it it still managed to push.Having no slashing propeller meant that any damage was minimal and the drive just slid over rocks and logs. Speed would depend on the rotation speed of the auger and most post hole borers run slow. I had 30 HP on one of my auger drive with a 3 speed gearbox. I would just love to have it back now.
#1169
| Could work I have an ice auger that will drill hole after hole until the motor would run out of gas. It is really geared down however and I don't think it would spin fast enough to propel a boat. I wonder if the motor was geared differently if it would go through mud like you are trying to do. I'm not clear Tom, did you already build one of these with the 45 cc motor or are you going to build one? Mark W |
#1170
| I have not converted a post hole borer but I did use an auger (a progressive pitch from butter packing machine ) on a boat with a Ford 10 inboard and 3 speed gearbox. The pitch of the auger would determine the amount of water and the speed (pretty slow without a gearbox with high ratio) Great in mud and sand and has a lot of prop walk. The screw was not steerable just ahead and a rudder to steer which was not very effective at times. I wish I still had it now.
| To those who want to convert a weed eater... | friedlbug | Propulsion | 35 | 05-14-2012 12:39 AM |
| Solomon Technologies - "Electric Wheel" electric motor propulsion systems | lockhughes | Hybrid | 228 | 10-12-2011 04:00 PM |
| Auto engine marinization | DIY Marinizing | 231 | 07-01-2010 07:34 PM | |
| Luhrs T-29 (1995) diesel inboard converted to outboard | Iya | Boat Design | 13 | 03-07-2007 06:48 PM |
| gearboxes and potential | bobber | Boat Design | 38 | 04-03-2005 11:22 AM |
