#826
| Let me know Quote:
Mark |
#827
| For Jobber if you want a long shaft air cooled the easy way is just get an old 4 hp longshaft outboard and stick a briggs and stratton mower motor on the top the photo is of a 4 hp Suzuki with a bs |
#828
| Mark I wish I had known you were having a problem with your engine. Those motors are fairly simple to service. If it has spark , compression and fuel, we can make it run. Let me know if all three are present and we will go from there. |
#829
| A duropower question for john John, it appeared that you were working diligently on your duropower conversions, but then switched over the the greater HP longtails from SouthEast Asia. Was the duropower just not enough power for your needs? Do you still recommend the duropower unit as a very workable setup? I seems like everyone that was so jazzed about this unit has moved on to other solutions. Thanks in advance, Ed |
#830
Mark |
#831
| as a help to everyone ...an HT spark in air must jump 1/4 inch if it is to jump the plug gap under compression.....its no good just taking the plug out and seeing if it jumps the gap....and the colour of the spark makes no difference its only the metal particles from the electrodes that colours it .... |
#832
| What are you saying ? Quote:
This motor went bad right after the pull start broke. When replaicn ght epull starter, I cracked a part of one of the mounting bolts for the starter. Didn't affect the integrity of the motor and the compression checked out OK for me to confirm this. Fors some reason, the motor will not start. I would sure love to get this thing running again. Any suggestions are appreciated. Maybe I can post pictures. Mark |
#833
| provided the gap between your " black box" and the flywheel is minimal then there is little you can do to increase the voltage other then fit a new box. check there is no deris ..iron fillings etc between the box and the flywheel . gap about 5 thou of an inch box core to flywheel The box is in fact a magneto coil with electronics instead of the old contacts . they are ususully reliable. the only other thing I can think of is that you have moved the flywheel on the crankshaft but this is not usually possibe as it has a keyway ..and I dont think you removed the flywheel when you did the starter cable .... The look of the spark has nothing to do with it ..its how far it will jump in air that counts |
#834
Thanks for giving me the option. I will think about it and let you know. Thanks again. Chris |
#835
| another question Quote:
Could I have moved the flywheel on the crankcase? It was immediatley after I did this that the motor would no longer fire. How do I check and then fix this problem. Is it possible. Sure would love to get this motor running again. Mark |
#836
| Mark; That particular motor uses a removable steel flywheel key. It only goes in one way. I seriously doubt if it sheared or changed it`s correct index. Here`s how to check it . Put a couple of screw drivers behind the flywheel and exert a pressure onto the flywheel as to remove it . After removing the retaining nut hit the end of the shaft with a hammer , the flywheel will pop loose. Check that the key is in the key way slot on the shaft. If everything is OK reassemble. Now to set the air-gap on the magneto/coil assembly. Loosen all the bolts that hold the mag in place. Now place a standard business card over the magnets on the flywheel and rotate the flywheel around until it is directly under the magneto/coil unit. The magnets in the flywheel will pull the magneto down onto it with the business card sandwiched between . Now tighten all the retaining bolts. Remove the card and the air-gap is set. If it still wont start I would suggest purchasing a new mag/coil unit from a supplier. Let me know I have a list of them if you need it. |
#837
| You may want to use a brass hammer or put something soft between the hammer and the shaft to prevent distortion of the shaft by the hammer blow. I'm just sayin'... ![]()
__________________ Hoyt Lighting is very selective and will not strike crap. Wynand N http://www.genocidewatch.org/southafrica.html http://www.saabc.net/ |
#838
i have been very interested in this but i dont see how you are attaching the the shaft to the lower unit? i have seen the ways some guys do it but they have vibration problems. How did you attach the motor shafts together? ![]() |
#839
| oh thats easy ..the end of the shaft down to the gearbox is splined so .take the crankshaft out of the old engine and chop off the end with the female spline inside it ....maybe turn in lathe or otherwise register with the end of the b/s motor crank ( maybe shorten the shaft on the b/s) and weld it in place ...make colar ..use keyway etc whaterver you have facility for ....This means you can lift the b/s on and off as you make your adaptor block ...take the water pump bits out ..... 8 inch pitch is about right . |
#840
| ohh so i would take the crank out of the old motor, then baiscally adapt it to the lawm mower motor. i get it thanks. |
| Solomon Technologies - "Electric Wheel" electric motor propulsion systems | lockhughes | Hybrid | 228 | 10-12-2011 05:00 PM |
| Auto engine marinization | DIY Marinizing | 231 | 07-01-2010 08:34 PM | |
| To those who want to convert a weed eater... | friedlbug | Propulsion | 33 | 01-21-2010 01:02 PM |
| Luhrs T-29 (1995) diesel inboard converted to outboard | Iya | Boat Design | 13 | 03-07-2007 07:48 PM |
| gearboxes and potential | bobber | Boat Design | 38 | 04-03-2005 12:22 PM |
