  #571
Old 06-21-2009, 05:24 PM
pistnbroke's Avatar
I try
Rep: 372 Posts: 1,230
you can see a lot of bearing photos on a 6.5 if you look on my seperate thread .... Thai longtail with 6.5 lifan honda.....it uses a taper roller bearing ...grease is bad due to the power loss in the tube to turn the shaft in the grease ...two part shaft ..new idea but needs support ...my shaft is 8mm stainless steel roller bearing at each end a bronze bush in the centre ....you are right to go with the bigger motor ..they are very cheap on e bay and the finished job is much more satisfactory in operation
  #572
Old 06-21-2009, 09:13 PM
muddin redneck's Avatar
muddin redneck muddin redneck is offline
DO IT IN THE MUD!!!
Rep: 26 Posts: 94
pistnbroke i am including a crude sketch of my motor plan i would like any input you have on my design, after looking at my sketch i noticed that i could not put on a skeg any ideas on that and is it truly nessecary
  #573
Old 06-21-2009, 09:16 PM
DO IT IN THE MUD!!!
Rep: 26 Posts: 94
also any ideas on where to purchase a prop for larger motor. the places i have looked all the props are in the $200-$300 range and i was hoping for a bit cheaper. do you know if an old outboard motor prop could be retro fitted to work or do you think they are to large
  #574
Old 06-24-2009, 10:17 PM
wac m trac m wac m trac m is offline
Rep: 10 Posts: 75
That bottom support will need to have pivots as well.
I would think the exposed shaft would be dangerous since things would get caught in there..especially down in the water.
  #575
Old 06-24-2009, 10:22 PM
Rep: 10 Posts: 75
now that I look again that bottom support wont work. Unless you used piston thing like you see on SUV rear doors. Maybe a small shock might work.
  #576
Old 06-24-2009, 10:34 PM
DO IT IN THE MUD!!!
Rep: 26 Posts: 94
yea my design is still being tweaked
  #577
Old 08-06-2009, 12:48 PM
Mark Wo Mark Wo is offline
Rep: 38 Posts: 115
What the heck?
Over 1.5 months and nothign new to report or post. This has to be a record for this thread.
Mark
  #578
Old 08-06-2009, 06:10 PM
pistnbroke's Avatar
I try
Well we have found some 2 to 1 gearboxes in New zealand ... direct bolt on the the lifan/honda but the makers are being difficult about supply details and I have had some private e mails from makers asking advice on the chain drive
  #579
Old 08-06-2009, 08:07 PM
ben2go ben2go is offline
Boat Builder Wanna Be
Rep: 13 Posts: 130
What about using a small block chevy timing set?Kind of expensive but something close would work.I used to cut straight tooth gears.They are noisy but something like the air cooled VW gears are quite in comparison.
  #580
Old 08-07-2009, 10:07 AM
Rep: 38 Posts: 115
Keep us updated on the gear reducer
I'd love to see what you have found and hear more about it when you get a chance. A 2:1 reducer would be a great addition to that Lifan/Honda motor.
Mark
  #581
Old 08-07-2009, 01:09 PM
Gholspawn Gholspawn is offline
could you send me plans please
  #582
Old 08-07-2009, 05:41 PM
Rep: 10 Posts: 75
Hey John O neal, hows your blue northern tool/lifan moter coming along. What you had looked good..any progress?
I'm thinking I might just buy a Utah Marsh moter instead of building one. They are a great price compared to anything like them..of coarse then I can say I made it..lol
  #583
Old 08-08-2009, 12:11 AM
Rep: 13 Posts: 130
This thread is the plans.
  #584
Old 08-12-2009, 04:19 PM
John O`Neal John O`Neal is offline
Rep: 29 Posts: 85
Wac M ; I have gotten sidetracked by my golf game. I have been struggling to break out of the 80s. My best so far has been an 81. Hunting season is fast approaching so it`s time to get back to work.
A short time back I purchased another Lifan on the net with 30 min run time for $85 . It is a 97cc 2.8 hp . It only weighs 23 lbs. I plan to use it on my layout to replace the 52cc brush cutter conversion I have. I plan to make it a direct drive utilizing a shaft coupler (no U-joint) 1 1/4 " alum. boom tube. 1/2" drive shaft. A very simple design to keep it lightweight.
  #585
Old 08-12-2009, 09:27 PM
Rep: 38 Posts: 115
Question on the Lifan
Hey John -
Is this a 4 stroke or two smoker, I can't remember?
If it is a 4 stroke, do you have any concerns with the oiling of the motor and the associated problems that John had over at Rickshaw? I know he tried the bigger honda motor (4 stroke) and had the engine seize due to the oiling not working correctly. I believe the motor could only be off level a small amount or the potential for what happened to Rickshaw would happen over and over again. If you haven't been to the Rickshaw site since July 4, he has written about the Honda and a high end 2 stroke (tanaka I believe) that he tried as well.
Just curious.
I have yet to have the new mud motor in the water yet can you believe it. There is never enough time in a day. Plan is for Friday weather dependant.
Mark
Solomon Technologies - "Electric Wheel" electric motor propulsion systems lockhughes Hybrid 228 10-12-2011 05:00 PM
Auto engine marinization DIY Marinizing 231 07-01-2010 08:34 PM
To those who want to convert a weed eater... friedlbug Propulsion 33 01-21-2010 01:02 PM
gearboxes and potential bobber Boat Design 38 04-03-2005 12:22 PM
