Old 11-02-2011, 02:28 AM
MihaS MihaS is offline
Rep: 29 Posts: 18
VW/AUDI 3.0TDI marinising
Hi to all
I start to marinize vw/audi engine 1 year ago.And now project will proceed,but I have few questions if somebody can help.
Engine is V6 3.0tdi with 233ps with 450nM torq used in all high class cars from their brand.Its also used in original VW marine/CMD marine./vw 6-265 model.
So engine is turbocharged-intercooled and can achive 275ps and 550 nm torq with chip tuning.
I buy original exhaust from vw marine,front mountings i made from inox,then i have to turn around 140a generator,because there is rigt side mounting. I made flange to fit mercruiser.And I use intercooler and heat exchanger from company SCAM Rijeka(croatia).
Then was a lot of work with electrical wiring and ECU,because car have a more indicators that station engine.
RAw water pump I use 1
Now the questions:
1.for heat exchanger I buy scam
http://scam-marine.hr/view.asp?language=english&idlan=1
but when I was checking original engine ,the size of heat exchanger is 1/2 of this SCAM. SO can I use smaller one.Like 300/100.?
2. WHich flexibile coupler some sugestions(flywheel is 280mm). I was looking this
http://scam-marine.hr/view.asp?p=205&c=56
Uh
Motor runs good and very smood,best! Pictures and movie I will attach later.
If you have any sugestions please advise.
I will have more questions later sure
Thanks
Old 11-02-2011, 06:56 PM
altinlala altinlala is offline
Pics
Looking foreward...
Trying the same two times for my new Riva Aquamarina.
Old 11-03-2011, 03:23 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,252
The Scam heat exchanger page says "no data".
As for the engine coupler, this is a smooth running V6 so you can use any coupler that fits the Mercruiser splined shaft, like the ones offered by Sierra marine. You may have to drill some additional mounting holes in the flywheel, but since it is cast iron that is no big deal.
Old 11-03-2011, 02:08 PM
Rep: 29 Posts: 18
Hi
You can see pictures os my first engine marinisation on this link.
https://picasaweb.google.com/1046171...M-YwYyzkK6bMg#
Old 11-03-2011, 02:23 PM
Rep: 29 Posts: 18
In first post i write that i will instal heat exchanger SCAM 400-130, but i see that I have in my garage 300-130.
So the 300-130 have cooling area 0,99m2, but this piece is very hevy and like i told you, original VW marine have 1/2 size of this. Can I install smaller 300-100,which have 0,60m2 cooling area.
Are any calculations about how much cooling area per PS
CDK. I know that this engine is very smooth running,but we cant easy balance mercruiser coupler on homemade flywheel.
Can you advise me any other conection(rubber) between pump and crankshaft.
Thanks
Old 11-03-2011, 02:28 PM
Rep: 29 Posts: 18
VW marine heat exchanger
https://picasaweb.google.com/1046171...0057/101MSDCF#
Old 11-03-2011, 03:12 PM
Rep: 29 Posts: 18
http://scam-marine.hr/view.asp?p=39&c=5
Old 11-03-2011, 08:56 PM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
Originally Posted by MihaS View Post
Hi to all
Now the questions:
Uh
Thanks
The motor you are playing with is the same as the Hyundai 3 litr marine engine check out this place http://www.hyundaiseasallusa.com/S250_Engine.php
Making beautiful boats is a passion never a chore !
Old 11-04-2011, 01:39 AM
Rep: 29 Posts: 18
How the same?
Hyuindai - VW
Old 11-04-2011, 02:16 AM
old one !
vw /hyundai motor just its a much better motor , is made of differant materials and lighter weight and much stronger all over . is much more economical to run and very smooth motor when going . you should look seriously at the pictures and check it out thouroughly go to hyundai site in South Korea .
Old 11-04-2011, 02:36 AM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1693 Posts: 5,867
If you going to marinise look for something from a 4 wheel drive , reason being torque.
You need torque and then some, no point in a little deisel out of a Golf.
You need one out of a pick up truck and there is loads of em in the 2.5 3 liter range.
Mitsubishi, Isuzu, Ford, Mazda ( same) and best-- Nissan they already have a marine Nissan.
Old 11-04-2011, 02:58 AM
Rep: 29 Posts: 18
I didn find any Nissan inboard engine.
Maybe on the market is any other better engine,but for VW I have trust and parts are available on every corner in Europe.
Maybe you dont know ,the heaviest part of marinisation new style engines is ECU remaping,so for VW I know how it goes.
Parts wich you can buy is best way to buy if thr price is reasonable.Exhaust is with discount is 500€,but for example intercooler is 3000€.
HYUINDAI is sure good engine, but im not looking which engine I can buy for 25000€.
Im small maker of pleasure boat in SLOVENIA and I install in my model from MERCRUISER 5.0mpi,STEYR diesel 144ps, LOMBARDINI MARINE 200ps.
With Steyr ,boat achives 27knots -bravo 3 20pitch props
Lombardini marine is 5 cilynder engine and have a lot of torque boat achives 37knots with Bravo 3 and 26 pitch
I have trust in Eu brands of engines,so i will proceed with them.
Old 11-04-2011, 03:09 AM
Frosty's Avatar
http://www.marinedirect.com.au/catal...egory663/c2477
Not necessarily for you but for others who may not know about Nissan conversions. Very nice sweet engine in my opinion.
Old 11-04-2011, 03:10 AM
CDK's Avatar
CDK CDK is offline
retired engineer
The 300-130 seems the right size to me.
I assume the construction is about the same as Bowman. Their smallest exchanger is the GL-140, rated very conservatively at 240 hp. It is slightly larger than the 300-130, so I cannot imagine an exchanger with half that size having the same capacity.
Please explain what you mean with 'balance mercruiser coupler'. If you made your own flywheel you will certainly be able to attach a coupler to it. Should the protruding rubber part bother you, cut a ring of sheet metal with the same diameter as the flywheel and use that as a template.
Old 11-04-2011, 03:30 AM
Rep: 29 Posts: 18
Ok thanks for yours opinion,but in second link which I send ,there you will see original size of heat exchanger. But guys from SCAM they told me that this original is made like from VOLVO KAD44 or others ,not just tubes also alum plates. And those plates make bigger m2. What do you think?
For balancing i mean in German language zentrierung, i know that i can balance on router. But all together, flywheel and coupler must be centered in center so i have to find some company. I allready make coupler on smaller diameter like my flywheel but centering on outer diameter it seems to not be good idea,because shaft is in center,mercruiser coupler is made in not so precision, outer and iner diameter seems not be balanced.
Marinising. Biggles Open Discussion: All Things Boats & Boating 3 05-22-2010 04:23 PM
Marinising a Kubota V1505 Marco1 Inboards 9 10-27-2009 09:34 PM
Marinising a 2.5 td Transit siyman Diesel Engines 1 06-24-2009 07:20 PM
Peugeot xud9 marinising leomagill DIY Marinizing 2 01-08-2008 12:44 PM
Engine marinising Hiptrip DIY Marinizing 19 06-04-2003 02:22 PM
