| Volvo 270 drive w/Ford 302? Hey, I bought a boat that has an Volvo AQ130C motor w/ 270 drive. The motor needs to be rebuild. I can get an (Auto) Ford 302 for cheap, what would it require to make it fit onto the 270 drive? and to convert it to a marine motor. Thanks Dan |
| Rebuild the 130. It'll be sooooooo much cheaper and easier in the long run. Check out this thread on marinization http://boatdesign.net/forums/showthread.php?t=650
__________________ Craig Cavanaugh Silver King Custom Marine No shoes, no shirt, no problem! |
| Lord's Prayer Hello, my name is josh, I'm extremely curious about the Ford 302/270inboard hook up that you talked to dan about. I love horsepower and I would love some info on what to do with my Glastron V184/with a volvo270 so I can have some fun. |
| Dan- Rebuilding the 130 would probably be easier than trying to cram a car Ford in there. Josh- Sell the Glastron and buy an old Hydrostream. That'll get you some fun! (Actually, there's a fair bit you can do with the Glastron- what powertrain are you running now? There's a lot of add-ons you can put on some of the common engines.)
| If you increase the HP, then you'll have to change the gear ratio. It is quite expensive. Also, the prop will have to match. Hotrodding is not for the poor.
__________________ Gonzo |
| Volvo Penta SP drive no reverse | Bragg Brothers | Sterndrives | 5 | 08-10-2011 11:46 AM |
| volvo penta out drive | ketch22 | Services & Employment | 2 | 07-26-2005 08:13 PM |
| Volvo 270 gear ratio help... | Leon Phelps | Powerboats | 4 | 03-09-2004 02:12 PM |
| Volvo Composite Stern Drive | Jeff | Powerboats | 5 | 08-31-2003 04:48 PM |
| Need help with a part or number Volvo 270? | Guest | Powerboats | 4 | 07-10-2003 01:43 PM |
