#61
| Sorry, my last post was lacking brain matter. Yes, CDK, the issue of the wet exhaust was the reason I mentioned removing the turbo. There is more head scratching needed on my part. |
#62
| What if I remove the turbo and I replace the smaller intake manifold with one from a non-turbo to allow the engine to breathe properly? Then I have no need to reposition the wet exhaust manifold and I still have 70 Hp available to me. And does the turbo actually save fuel? I thought, based purely on logic, that if the turbo is giving the engine more power and anything that gives more power uses more fuel, then the turbo burns more, not less. |
#63
Regards Richard |
#64
| A turbocharger's role is to cram more air into the engine than it would be able to take in at ambient pressure, thus allowing it to burn more fuel and produce more power on each stroke. Generally speaking, any sort of forced induction device will increase cylinder pressures, which usually has the effect of improving efficiency (reducing specific fuel consumption). However, the optimum operating point will also change, so it is quite possible that a turbocharged engine, if run underloaded, may be thirstier than its naturally aspirated twin would be at the same load. (The more sophisticated multi-turbo, variable geometry turbo, variable boost, etc. setups tend to alleviate this drawback.) The only way to know is to compare the 'fuel maps' or 'performance maps' for the engine in both turbo and natural configurations.
#65
| Ja, that was the prolonged version. Better cooling (the intake vessel) is another point.......... |
#66
| More important is that the turbo will allow you to tap the power you need at lower rpms, as long as you don't need the max rpm power. This gives you higher propeller efficiency AND lower specific fuel consumption from the engine! So, whatever you do, keep the turbo, don't mess things up now!!!!! Better take some time and locate a watercooled exhaust manifold for this engine! They come ready and complete with engine heat exchanger from "Bowman" for example. |
#67
Moving the turbine to the exhaust flange of the manifold takes only 3-4 hours. If you replace the manifold and discard the turbine, you need to replace the injection pump as well or have it recalibrated for the reduced air mass. I'd rather spend some time moving the turbo charger. |
#68
| Got the Bowman. Spent the weekend staring at the current layout and thinking. I promise to not mess it up. I owe you guys that much. |
#69
| More important is that the turbo will allow you to tap the power you need at lower rpms, as long as you don't need the max rpm power. This gives you higher propeller efficiency AND lower specific fuel consumption from the engine! This is fine as long as the turbo is working , a problem comes in "no wake zones" where the engine might need too basically idle hours on end. IF long slow speed transits are required , usually a no turbo engine will have longer service life.Although the fuel burn will be higher . FF |
#70
| Fast Fred, I am a sailboat with 30,000 lbs of displacement and 6 feet draft, able to reach "top speeds" of about 6.2 knots. Sorry if I wasn't clear on that. No wake issues here. However, I like the overnight stop idea. May I send you a PM so I can plan for next time I head South? Monica |
#71
| Hydralign propeller All right, time has passed, new problems have arised. I always wanted a feathering prop, but the cost is well above my paygrade. Just found this on Ebay, seems to be the model for aperture setup, the seller confirmed the forward to stern dimension is only 3 inches. I am contemplating bidding on it. Here is the link http://cgi.ebay.com/ebaymotors/ws/eB...m=290497849814 What do you guys think? Last edited by sailingmonica : 11-12-2010 at 11:53 AM. Reason: used wrong word |
#72
| Hi, guys! Cavitation problem SOLVED! After a few years and a few propellers (expensive testing, I tell ya'), all cavitating at 5 knots and over and none allowing the engine to reach its full RPM, we stumbled upon a Hydralign Feathering Propeller on EBay. Long story short, I bought it. I then contacted the manufacturer in Australia and asked for the pitch adjustment table; while we were talking I told the guy that I am trying to figure out what the pitch should be. He asked for the usual boat specs and then came back with 18x7. Yeah, right, I thought! But I was willing to give it a try, since I already tried everything else. So I set the pitch at, well, 7.9, put the boat in the water and floored the throttle. Wow! I got up to 8 knots, no banging noise, RPM going up, engine happy and the boat was barelling down with bow up and the swim platform almost in the water. I even had a wake! Then I tried docking, no problems there either. Perfect control. So I am happy like a pig in a mud bath right now. Why it works at this pitch, I don't know. |
#73
| I'm glad it's working for you now, Monica I hadn't heard of the Hydralign brand before, but they appear pretty well engineered. (for others' reference: http://hydralignprop.com/propellers.html )
#74
| Marshmat, the Hydralign is the only feathering propeller manufacturer I know of (and as I said I found out by mistake while browsing Ebay) that actually makes feathering propellers for apperture setting. Instead of those long hub props you see all over, this one is only 3 inches. See attached for sizing reference only (that's my husband trying to figure out how to adapt the extractor to the new prop). |
| Resistance Calc | Anoop_ODL | Boat Design | 14 | 11-16-2009 12:35 AM |
| VolksWagen TDI 225-6 diesel price? | old750 | Diesel Engines | 6 | 12-17-2007 07:23 PM |
| Lamination Calc Service | JEM | Fiberglass and Composite Boat Building | 1 | 04-27-2007 10:59 AM |
| Volkswagen diesel powered sport fisherman | GeoffSChapman | Propulsion | 5 | 06-02-2005 03:36 AM |
| Calc centerboard length | sroberts | Boat Design | 1 | 10-06-2004 08:09 AM |
