Old 10-26-2005, 03:25 PM
welding rod welding rod is offline
Rep: 10 Posts: 2
truck engine/trany needs thrust bearing
I have a 47 ft motorsailer. I have a ford f-250 with 6.9 l diesel and manual tran. I plan to put engine and trans in boat. Engine rated 175hp@3800rpm. I will use about 80 hp@2200rpm. Keel cooling, dry exhaust, heavy duty marine alternator. standard shaft/prop installation. Reason, old mercedes engine, ie expensive hard to get parts.$500 water pump! $40 for ford. PYI has thrust bearings,to expensive. Bearing suppliers have dual acting thrust bearings,just like PYI uses $2-300. I need good ideas on simple ways to mount bearing between flange on end of prop shaft and transmission.
I understand a marine engine/tran is a better solution. This way will cost about $1500. I have all materials on hand except bearing and shaft. Boat is steel so mounting bearing securely is not a problem.
Old 10-28-2005, 12:11 AM
gonzo gonzo is online now
Rep: 1397 Posts: 7,215
You can rebuild the Mercedes for $1500. Are you sure it is worth your effort to install an engine that is not designed for the application?
truck engine/trany needs thrust bearing welding rod Powerboats 1 11-04-2005 06:27 AM
Propeller THRUST WilliamS Boat Design 9 10-08-2005 06:31 AM
Coefficient of Thrust Calculations......Urgent help please! Biomechanist Boat Design 7 11-06-2004 02:08 PM
Prop Thrust Calcs / Bow Thrusters jocko_nc Boat Design 0 04-20-2004 07:32 PM
Help, Thrust Generated By Outboard Guest Boat Design 3 11-12-2003 03:02 AM
