  #76
Old 06-08-2010, 12:40 PM
riverrat87 riverrat87 is offline
Rep: 10 Posts: 2
Hey guys, I'm attempting to follow in yalls footsteps with a 6.75 briggs off of a pressure washer and I'm not sure how to figure out what sprockets I need for the right gear reduction. Any ideas? Thanks in advance.
  #77
Old 06-08-2010, 04:25 PM
thudpucker's Avatar
thudpucker thudpucker is offline
Rep: 343 Posts: 724
Keep the B&S running at 3600 Rpm.
Now you need to know the prop Pitch, and Diameter.
Then you get the info on the load that will create.
Then Gear the engine to the Prop using percentages.
Then convert the percentages so Sprocket sizes.
  #78
Old 06-08-2010, 04:28 PM
pistnbroke's Avatar
I try
Rep: 387 Posts: 1,269
anything around 2 to 3 to one seems ok depends what prop you have to hand you could try to match it . .I think my big cog is 28 teeth small one 12 ..if you go much bigger in teeth the large cog gets physically quite big . If you can do a double chain its even better. I think Mc Master Carr have a selection of cogs mail order
You can get b and s with reduction gearbox attached
  #79
Old 06-08-2010, 04:51 PM
Rep: 10 Posts: 2
I haven't got a prop yet, should I go with a three blade or two blade
  #80
Old 06-10-2010, 07:11 PM
rmenasco rmenasco is offline
Rep: 10 Posts: 40
Pistnbroke,
I have really been looking around a lot on the internet and I found a company over here in the states that is commercially selling the same thing that you have built for around 1000.00USD
Here is there site....
http://www.scavengerbackwater.com/
advice on Thai Longtail boat project napalmtheelf Projects & Proposals 36 03-02-2011 09:26 PM
10M Thai Long Tail S.E.A. Post-Tsunami 44 06-20-2009 11:00 PM
weedeater longtail caveman DIY Marinizing 8 10-01-2006 05:32 PM
Thai Long Boat Plans? tregosoaker Boat Design 10 05-24-2006 08:54 PM
26" Bristol, needs new 6HP outboard ridgemd Sailboats 4 08-01-2005 06:40 AM
