Old 05-19-2010, 07:50 PM
muddin redneck's Avatar
muddin redneck muddin redneck is offline
DO IT IN THE MUD!!!
Rep: 26 Posts: 95
Speed Problem???
i just got through building a 24 hp mud motor a friend has one very similar his is on a boat with a 16" transom and mine is on a boat with a 21" transom would this height difference make a big difference in the top speed the of my boat which is shorter and lighter than his?
Old 05-20-2010, 04:18 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,357
The direction of the force vector will change with an increase with the height of the transom. The closer the transom top to the water, the more force will be directed backwards rather than down. The force lost in forward momentum with the higher transom will be used trying to pull the stern up.
Hoyt
High Speed - Low Speed Small Disp Diesels tranmkp Diesel Engines 18 02-12-2009 06:21 AM
merc 20, hi speed problem starville Outboards 4 05-15-2008 10:27 AM
Problem with Props revs and speed Fantasy 3 Propulsion 1 09-23-2005 05:16 PM
Speed/slip problem Per S Props 43 07-17-2005 02:33 PM
speed & Trim angle curve by maxsurf, hull speed Joe Lu Software 1 11-25-2004 06:37 PM
