Old 03-29-2011, 08:36 PM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1693 Posts: 5,867
The prop size would be like the drive belt width on your snowmobile.
Would'nt get far if the belt was only 1 foot wide!! lots of slip.
Old 04-03-2011, 10:01 AM
racing fan racing fan is offline
Rep: 35 Posts: 104
yea well i think of somthin i guess thanks guys
Old 05-17-2011, 08:06 PM
claydog claydog is offline
Rep: 37 Posts: 41
Frosty, you were talking about the track being a foot wide and not the drive belt weren't you? Traction (slip) on a snowmobile is mostly governed by lug height and stud count, track length and width effect "floatation" more than traction.
FYI, common snowmobile tracks range from 13" to 16" wide X 120" to 162" long, drive belts range from 1.5" to 2" wide.
Old 05-19-2011, 01:53 AM
powerabout powerabout is offline
Rep: 484 Posts: 1,431
Originally Posted by racing fan View Post
all snow mobile engine are horizontal but there is no reason a 2 stroke cannot run on its side there is no oil in in the bottom like a 4 stroke so if i flip the cab by means of a machined plate in between it it will run fine but
where do i get a short shaft mid and lower unit for it that's in good condition???
people have flipped 2 stroke before why not now
Not neccesarily, oil is still pumped to the top bearing of an outboard from low points in the engine you will need to sort that out.
Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers.....
Old 05-19-2011, 06:06 PM
Rep: 35 Posts: 104
in two stroke motors the gas/oil mix travels to all the parts that need oil but if you flip the motor and rotate the carb to get it to run you will have a prob but if you managed to get a fuel injected one or a fuel pump you will be able to sort that problem out
Snowmobile engine boat Minnesotaman Boatbuilding 13 02-08-2011 04:50 PM
Outboard Snowmobile engine fish2603 Propulsion 2 11-20-2005 08:18 AM
marinizing a snowmobile engine and drive setup? rvBilly DIY Marinizing 2 09-07-2005 07:50 PM
How to make snowmobile engine work in a small 11 ft. runabout? rvBilly Propulsion 8 09-02-2005 09:49 PM
What's the best automotive engine to convert Adz DIY Marinizing 6 08-16-2005 09:01 AM
