Old 05-14-2007, 03:57 AM
martinwill martinwill is offline
Rep: 18 Posts: 14
Sacraficial anodes
my petter ph2w is raw water cooled but i cant find any sacraficial anodes on it, can i fit them and how do i go about it
Old 05-14-2007, 04:24 AM
Previous Member
Rep: 0 Posts: 0
did you check the cooler, underside?
somewhere there maybe plugs, in the cooler , or jacket water
jus keep on looking
You know there maybe too many zincs, slower diesels are less subseptible to (electronic mice)
Old 05-14-2007, 10:57 AM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1528 Posts: 5,518
You may not have them-- do you have a zinc on the shaft?
If so then the shaft should be connected to the engine. I mean electronically via any drive hubs.
This may be sufficient. Why dont you check with Petter?
Petter PH2W anodes martinwill Diesel Engines 1 05-10-2007 05:01 PM
Aluminum and anodes in freshwater SWHNA Boat Design 1 04-27-2007 08:38 AM
Anodes sailrjim Metal Boat Building 9 12-04-2005 05:48 PM
