Old 04-19-2008, 03:08 PM
charlesakeem charlesakeem is offline
Rep: 10 Posts: 42
Rebuilding and marinizing tractor trailer
okay this is an idea for a catamaran to be powered by 2 400-500 hp
diesel engines from a commercial tractor trailer.
The proposed cat is a 70+ cat made out of steel or aly going to try and pick a metal after my idea get bombed and torn apart in my other topic
what would go in to marinizing an engine like that.
About me
Competent but not extrodinary carpenter
amateur welder and machinist
bio diesel enthusiast
has access to small foundry and potential to build a large one
I also have a few good friends who have the following skills
master carpenter
mason
Under water welder
electrician
car tuner
cement man
forester
sailor
and access to tons of free labour
and some industrial machining tools that i get to use from college or have a friend machine something for me from on base
heres a volvo 465 horse power 11,000 bucks
http://www.trucks.com/parts_spec_she...keSearch=VOLVO
heres a 525 horse power 8,900 bucks
http://www.trucks.com/parts_spec_she...ER&makeSearch=
plenty of others here
http://www.trucks.com/parts_inventor...sort=1&dir=asc
I admit to being pretty inexperienced but hey i'm giving my self about 5 years to learn before i build
Last edited by charlesakeem : 04-19-2008 at 03:16 PM. Reason: forgot to add the links for the engine
Old 04-20-2008, 06:56 AM
Rep: 700 Posts: 3,208
You are WAY out of line on the size engine required , far far smaller would be better choice.
If you have the vessels displacement in pounds divide by 2240 and you will have the weight in tons.
The combined power you need is at MOST (unless you are dreaming of towing water skiers) is 5 hp per ton.
This gives 2 1/2 hp per ton , on single engine operation , still enough for reasonable speed.
A pair of early International DT 360 or DT 466 , non turbo , non electric injection would be OK choice , and mates I think to a SAE 2 tranny pair (Twin Disc if uoiu have the bucks).
PBB Pro Boat builder has an article on keel cooling and dry stack exhaust on line for free , and is simplest way to marinize a commercial engine.
FF
Old 04-20-2008, 09:06 AM
Pericles's Avatar
Pericles Pericles is offline
Rep: 1040 Posts: 1,645
Hello there,
FF has given you the clues. Here are the articles.
http://www.proboat-digital.com/proboat/20080203/ Page 66
http://www.proboat-digital.com/proboat/20080405/ Page 48
Here are the rest of the magazines on the Internet.
http://www.proboat.com/
There is a massive amount to read, but the answers are there. Good fortune on your project.
Pericles
Whilst entitled to your own opinion, you are not entitled to your own facts!
Old 04-21-2008, 11:06 AM
Rep: 10 Posts: 42
Thanks for the link will read that article then I am going to start at the beginning and work my way through I'll probably have a blaze of posts after I'm done with this
Modern 350 Marinizing LMannyR DIY Marinizing 45 09-24-2010 08:14 PM
Is there a More Active Marinizing forum? LMannyR Gas Engines 0 03-03-2008 09:36 PM
Marinizing a 350 jaydubya999 Gas Engines 9 07-17-2007 08:08 PM
De-Marinizing morbidflorist DIY Marinizing 19 06-06-2006 10:12 AM
Marinising New Holland Tractor Diesel Bradley Powerboats 8 03-05-2005 05:55 AM
