Old 07-27-2011, 05:16 PM
Rangerspeedboat Rangerspeedboat is offline
Rep: 17 Posts: 120
Prop shaft seal
Where can I get a shaft seal for a 1/2" shaft? I'm working on an inboard canoe with a Briggs 6.5 horizontal shaft. I would prefer something that doesn't leak or drip. The one of the things I considered was an old automotive water pump.
Old 07-28-2011, 03:10 AM
tom kane's Avatar
tom kane tom kane is offline
Rep: 287 Posts: 887
prop shaft seal
It would appear that you could have your seal above water level which is a sensible idea and it will not leak.Perhaps usual plumming fittings and a hemp seal would be good.
The rubber hose in the image could be longer up the shaft.
tomkane
Old 07-28-2011, 03:41 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,252
There are plenty solutions possible. Tom Kane's stuffing box is one of them, but you could also buy a neoprene seal (simmer ring) or the ceramic seal for a garden water pump with 1/2" shaft.
Old 07-28-2011, 07:45 AM
Rep: 1729 Posts: 2,462
Yes seals are quite common around here on small runabouts with inboards. It's easy to get a springless lipped neoprene seal to suit any shaft diameter. The seal housing is often made with glass woven cloth and epoxy wrapped around the shaft tube end and the seal outer edge. Make sure it retains the seal ( wraps around over the outer face a few mm).
Mike Johns.
Old 07-28-2011, 11:06 AM
anthony goodson anthony goodson is offline
Rep: 241 Posts: 391
A piece of rubber hose with a couple of automotive grease/oil seals works well.Stainless steel hose clips hold both in place .and stainless steel seal springs ensure long life.Fill the gap between the seals with grease.
Old 07-28-2011, 10:45 PM
Rep: 1493 Posts: 7,447
Any grease that can leak into the water is a violation of the Law.
Old 07-28-2011, 11:59 PM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
..if you use typical shaft seals to do the job (and they will be quite OK for occasional use anyhow), simply remove the metal spring and replace with an O ring, I have done this many times and it works perfect.
Old 07-29-2011, 12:14 AM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1693 Posts: 5,867
Ha when you have a steel boat the only way to protect the inside of the log shaft is to pump it full of grease till the water behind turns blue.
Dont even need a seal with 4 foot of shaft in grease.
Old 07-29-2011, 09:43 PM
It may be allowed in your part of the world. However, it is a violation of national and international law.
Old 07-29-2011, 10:03 PM
Frosty's Avatar
While it is international law, the fishermen want to come into the marina to catch fish, they say there is better fishing. Never understood that will all the oil and antifouling around, and the mussels that grow off the pilings are delicious.
Old 07-29-2011, 10:07 PM
There's also good fishing at the sewage drain.
Old 07-29-2011, 10:15 PM
Frosty's Avatar
Thats true, maybe we got this wrong and fish like a bit of pollution, has anyone asked them.
Old 07-29-2011, 11:12 PM
Rep: 17 Posts: 120
Project is on hold for now, I found a different use for the motor. However my plan for a prop shaft seal is 2 sealed ball bearings inside a stainless steel tube, a thrust bearing incorporated inside the SS tube, with rubber oil seals at the end of the tube. I'll fill the tube with gear oil or grease to keep the bearings lubricated.
Oil not allowed in water? 2 Stroke outboards???????
Old 07-30-2011, 03:11 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Think about it some more. Sealed ball bearings are lubricated for life, oil or grease in the tube will never reach them, nor will it reach the rubber oil seals at the end. The outside one will survive because the water film protects it, the inside one will wear very quickly.
Also try to figure out how to fill the tube with oil and how to keep the thrust bearing in place.
Old 07-30-2011, 03:31 AM
pistnbroke's Avatar
I try
Rep: 387 Posts: 1,269
A four foot tube full of grease will absorb loads of power..a standard lip seal kept lubricated has been fine for me on the long tails.and its at the wet end ....your shaft must be well polished . lube the seal in gearbox seal which expands the seal and is a fantastic lub. A sealed bearing is to stop the grease comming out the bearing ..???
Prop shaft seal questions DougCim Inboards 1 08-05-2010 02:50 PM
Shaft seal dand0_4 Surface Drives 8 02-27-2010 09:18 PM
Prop shaft tube, bearings and seal design pdwiley Metal Boat Building 25 12-23-2009 09:22 PM
Prop Shaft Systems. Dhutch Inboards 83 12-13-2009 01:41 AM
Prop Shaft LADYLOVE Propulsion 0 04-30-2005 12:26 PM
