| please help the new guy!1st time in salt water 1st day aboard and 1st time in saltwater.I have a 1960 cruiser from C.C. with a 283 marine engine.I want to put her in the waterways and canals of south Florida.I was thinking to put a fresh water conversion on,but I,ve been told a moter with 1000 hours even though previously used in fresh water will be in trouble with antifreeze pumping thru it.Apparently it will react with any present corrosion to swell and start blowing gaskets.Any ideas or experiance on how to handle this? Off the top of my head I thought I would just cycle fresh water thru the motor at the end of each use,but I would really prefer to have it set up right.Please help the new guy.... |
| You can use two cycle, one for fresh water and one for sea water |
| Thanks for the quick response!Maybe since I,am new at this I dont understand.The boat will remain in saltwater.What is the two cycles you are refering to mean exactly? |
| Just another thought, that should be more than adequate... Install a "T" on the pickup side of the engine raw water, and pump fresh water through after every use. Easy installation Protects the whole system (vs just the engine) Cheap Mike |
| Thanks,Mike.Yea I heard about these but some guy at Dolphin marine says I wont be cleaning the salt water out of the block,just parts of the motor.Does that make sense?or is he trying to sell me a new engine...The engine itself has 1000 hours on it (freshwater use)so I suppose it,s life is limited even though she runs great at present.Also she will be docked on the water,so can I still flush her engines while she,s still in the water.I,am preety green at this....Thanks,John |
The fresh water will go everywhere the salt water goes! Quote:
__________________ Craig Cavanaugh Silver King Custom Marine No shoes, no shirt, no problem! |
| Salt 19 | Dessied | Sailboats | 3 | 09-08-2009 07:59 PM |
| 1st time boat restoration.. | Martell_Florida | Boatbuilding | 9 | 01-31-2006 08:49 AM |
| Want-to-be-sailer's 1st boat | redburk | Sailboats | 3 | 08-13-2004 12:13 PM |
| help in purchasing 1st sail boat | bc22 | Sailboats | 0 | 08-05-2004 03:31 AM |
| Density of Salt water | Willallison | Boat Design | 18 | 02-20-2004 12:12 PM |
