Old 12-12-2004, 12:57 PM
mcattac mcattac is offline
Rep: 10 Posts: 2
OMC Cobra to Mercruiser Conversion
With OMC out of the picture now, has anyone done this when it was time to rebuild/replace the motor and/or lower unit?
I have a 1988 25' Sportcraft Fisherman with an OMC Cobra 5.8 liter.
I was told the motor is a Ford 351 Cleveland.
Has anyone swapped out this motor with a newer comparible Merc.
Has there ever been a write-up on this.
What about the transom? Especially the lower unit hole.
Thanks.
Mac
Old 02-05-2005, 10:29 PM
Rep: 1397 Posts: 7,216
Is this one of the outdrives with the big round rubber gasket? The engine may be rebuildable, if not I can get you either a new or a rebuilt marine Ford.
Old 06-01-2005, 11:39 AM
Scott_CVX20 Scott_CVX20 is offline
Rep: 10 Posts: 2
Didn't Volvo-Penta buy the OMC I/O business?
Why don't you see if you can get marine parts from them? Or try eBay or the internet. Assuming the drive is still good, it's be a lot simpler and cheaper than swapping it for a M/C. If you had one of the old OMC, VP or Merc drives (77ish or earlier) I might think about an upgrade.
I/Os & Inboards have either Ford, Chevy, or Chrylser engines (Old VPs). for that stuff, just go to Jegs or Summit, or any parts dealer.
Scott
Old 07-18-2005, 01:47 PM
Dodgeman Dodgeman is offline
OMC Cobra
5.8L EFI is a 351 Ford. Like in a pickup.
The Cobra unit is the OMC version of the Mercuser.
I do not know if the lower unit componets will bolt up to the Mercuser stuff.
I think that Volvo Penta parts will work with OMC Cobra as I beleve that Volvo
bought the stern drive division of OMC from Bombardare.
Old 07-18-2005, 05:35 PM
There was a joint venture between Volvo and OMC for a short while. Those engines are available new or rebuilt. If the drive is good, that is the cheapest and simplest solution.
OMC Johnson 50 hp 2001 engine problem Guest Powerboats 8 11-05-2008 09:57 PM
bertram omc to mercruiser repower flex6000 Propulsion 6 09-08-2006 07:23 PM
Engine swap OMC to Mercruiser 4.3 CreoleIII Propulsion 0 05-17-2005 10:36 PM
Would like to replace 1989 5.7 OMC - Help! kakidsdsu Boat Design 3 05-08-2005 12:14 AM
Mercruiser 120 Replacement penguin Propulsion 1 04-23-2005 11:03 PM
