| MerCruiser 470 heat exchanger on a v8 engine? Hi Guy's Can some tell me if a Mercruiser 470 heat exchanger ( 4 inch round model ) would be ok to use on a small V8 engine , a ford 302, they look like a good size for the small block v8 and would fit in my application nicely Thanks in Advance Dave |
| well it would be close, the largest 470 design was rated at 188hp and a 302 with a 2 barrel was also 188hp from merc
__________________ Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers..... |
| Thanks for the reply I thought it would be close, as pleasurecraft make a 3 x24 inch for a small block ford, and the newer 470 is 4 x 27 inch in size Regards Dave |
| it all depends on your manifolds, if they are in the circuit and are small log style ski boat ones you might be in trouble as the water gets too hot in them before it exists. Cast iron never seems to have that problem.
| Hi, I run headers over the transom with mufflers, so no water thru the pipes |
| How can i start a inboard engine without the heat exchanger to see if it runs? | J Arena | Gas Engines | 2 | 04-10-2011 06:35 PM |
| exhaust gas heat exchanger | singleprop | Diesel Engines | 11 | 06-29-2010 09:17 AM |
| heat exchanger cleaning | kenJ | Diesel Engines | 2 | 12-15-2006 10:04 AM |
| Building a heat exchanger into the hull | djackson99 | Powerboats | 42 | 03-21-2005 02:15 PM |
| Building stainless heat exchanger | guest | Powerboats | 4 | 08-11-2004 03:46 PM |
