| Help very interesting tread .. I was just wondering if you can help me I have a bayliner with a 3.0 L mercruiser engine on an alpa 1 gen 2 stern drive the engine is on it last legs and I was thinking of installing a vw /audi 1.9 tdi diesel engine .. now here is the question what will i need to do to marinize the car engine and what can i use from the car engine and the mercruiser as i'm on a budget and any suggestion as where to get parts??? |
| Assuming you have access to an engine with a (partial) wiring harness, immobilizer, key lock, the control unit and wiring diagram, you need a water cooled exhaust manifold, a bell housing, raw water pump and lots of coolant hoses. The manifold and probably also the bell housing are available from Lancing Marine. You also need access to a machine shop and/or a skilled friend because you have to convert the engine coupler from the mercruiser engine so it fits the VW flywheel. And you have to make your own engine front support or adapt that from the mercruiser as well. If your budget is really tight you can make the whole bell housing yourself.
| CDK Perhaps I missed the post but are you making any progress with the tunnel hull and the two 1.9s ..now its summer in the med is it another period of experimentation? |
| pretty impressive stuff there C I really like the adapter plate
__________________ I am skeptical of the deniers diatribe |
I replaced the makeshift steel plate between the tunnels with a fiberglass bridge so no air can be sucked in anymore, replaced some badly corroded ball bearings on the rudder shafts with nylon bushings and improved the construction securing the rudders to the shafts. Then I sanded the hull and applied two coats of blue "hard matrix" antifouling from an Italian company called Veneziani because I've seen in the marina that it really seems to live up to its promise to keep the barnacles away for several years. What still remains to be done is to lift the port engine and have it overhauled, but as you remarked summer is approaching so that operation has to be postponed until the fall.
| You're not on a tight budget Frosty!
| VW Diesel Jet Boat :-) Lux-wales, Love the vid... What jet drive and impeller are you using? You do not need a transmission? RPMs are OK? Sorry for so many Questions... New to this boat design stuff Looking to build something similar.CDK Thanks for your info too! Very helpful. Hope to learn more and ask better questions soon Quote:
| The trick of marinizing a motor vehicle engine is in the choice of engine. 50% of the problems can be avoided by choosing the right one. |
#25
| Same goes for Women Frosty ... |
| Modern 350 Marinizing | LMannyR | DIY Marinizing | 45 | 09-24-2010 07:14 PM |
| Marinizing a 350 | jaydubya999 | Gas Engines | 9 | 07-17-2007 07:08 PM |
| De-Marinizing | morbidflorist | DIY Marinizing | 19 | 06-06-2006 09:12 AM |
| Mitsubishi turbodiesel | yokebutt | DIY Marinizing | 2 | 06-14-2005 10:38 PM |
| New Forum Proposal: DIY Marinizing Engines | gonzo | Forum Questions and Suggestions | 8 | 09-03-2004 10:06 PM |
