| Marinizing Holley Carbs - Gonzo? Gonzo (or anyone else who knows), I have a boat that came with automotive 4 barrel Holley carbs. I think I remember a post where you said you can use brake line to make J vents. Is that the only difference between the auto and marine carbs to make them safe?? The engines ran well with the auto carbs (just not safe). Thanks! |
| The auto carbs vent outside. I have used brake lines in a J to vent them in like a marine type. Also, if you have a screw to adjust the float and a side plug to measure the lever, you may want to change the side plug for one with the glass window. It makes easier and safer to adjust. I assume they have a flame arrestor installed.
__________________ Gonzo |
| Marinizing Small Industrial Diesels | Diesel Dan | DIY Marinizing | 32 | 08-12-2009 04:59 PM |
| first marinizing of my boat lots of questions | dumbjarhead | Open Discussion: All Things Boats & Boating | 12 | 01-05-2007 08:38 PM |
| Carbs | Sea Cruise | Inboards | 3 | 06-30-2006 04:04 PM |
| De-Marinizing | morbidflorist | DIY Marinizing | 19 | 06-06-2006 10:12 AM |
| gonzo...need some help quick | zr1_lt5 | Powerboats | 3 | 08-19-2005 12:28 PM |
