| To marinize or not to marinize that is the question A friend who is a shipwright told me I could set up a heat exchange by pipeing water from the radiator in a loop around the keel. I would have to create cavity (weld a plate along the length of the keel on both sides- Its a steel hull) and pipe the water from the radiator through this, then I can use any normal diesel engine. It is for a 40' steel sail boat. I'm not that keen on altering the shape of my boat where hull meets keel, not even a little bit. Its such a lovely shape already but not have to marinize is very attractive. A friend of my friend has circumnavigated three times with the same engine. Opinions? ![]() |
| We have a 50 ft Navy Utility Launch that is GRP. Its DD 6-71 has a dry stack and all the cooling is two lengths (21ft) of 1 1/2 pipe with a close nipple and two 90deg at the "far end". This system of keel cooling has worked for years , in warm Florida waters. Cheap , reliable and functional, No extra water cooling pump to maintain is great for FL sandy waters. FF |
| My mate who has made over 70 steel boats, regularly builds in a double bottom, it is filled with the radiator coolant mix like glycol and the engine runs through the double bottom fresh water system. i have not heard of any problems....are you there Mr. Yan?
| You can mount it on the outside of the hull quite easely here is a link http://allweatherboats.com/id10.html i am sure we will be seeing a lot more "old" technology with the current world wide inflation |
| See Dave Gerr's article on dry exhaust in Professional Boatbuilder magazine, issue 111, page 66, "The Dry Exhaust--Part 1", which you can read on-line at: http://www.proboat-digital.com/proboat/20080203/ The article covers the design information you need to know in order to size a proper keel cooling system. I hope that helps. Eric
| If you have a metal hull, just weld half-pipe on the INSIDE of the hull, anywhere you like, below the waterline. Make a single, continuous loop, sized appropriately for your engine. There was a lot of discussion a couple years ago, either here, or on the Metal Boatbuilding forum. [edit: http://www.metalboatsociety.org/ has extensive discussion of just these issues ] If you want heat sometimes, put a Y-valve to route the coolant through pipes in your cabin sole! |
| "If you want heat sometimes, put a Y-valve to route the coolant through pipes in your cabin sole!" I would add an electric circ pump., so if heat is required after shut down you can get it for free from the engine mass. With the Y valve in HOT weather the circ pump would cool the engine , making it easier to be aboard after shutdown. We have used the concept of an electric extra circ pump in our RV bus conversion , an 8v71 has enough retained heat (3000lb engine) to warm a cool evening at little cost . FF |
| cool thanks, good info. I'm gonna do that. |
| 200-250hp engine to marinize | bcervelo | DIY Marinizing | 13 | 02-28-2007 05:03 AM |
| Marinize a Subaru? | curtis73 | DIY Marinizing | 17 | 12-29-2006 02:21 PM |
| Why Marinize | briggsy | DIY Marinizing | 11 | 03-16-2006 03:51 AM |
| Want to learn to marinize diesel engines | SURFERBOY732002 | DIY Marinizing | 3 | 06-18-2005 07:27 PM |
