Old 06-30-2009, 05:12 PM
mesquito_creek mesquito_creek is offline
Is this a marine Holley Carb?
I am trying to go through my project and identify any "non marine" substitutes for safety... Can anyone identify this carb and verify if it is a Marine Application? I see the turned over vent tubes as "marine" but that is all I can figure out. I have got close on the model numbers with Google but not exactly.
HOLLEY
R84023-3
1367
It sits on a Volvo Penta Small Block Chevy motor
Is this a marine Holley Carb?-holley1.jpg  Is this a marine Holley Carb?-holley2.jpg
Old 06-30-2009, 07:40 PM
fasteddy106's Avatar
fasteddy106 fasteddy106 is offline
Rep: 171 Posts: 72
Write down all the numbers you can find on the carb. Holley usually puts a number on the air horn. It should say .... "List" followed by a number that starts with an R.
Then go to the web site below and contact the customer support dept. or use the search function to identify the carb.
Good Luck..........
http://www.holley.com/TechService/
Old 06-30-2009, 08:47 PM
Rep: 2891 Posts: 8,792
Yep, that's a marine grade (see the "J" tubes) 4150, duel feed, double pumper with vacuum secondaries.
Old 07-04-2009, 01:54 AM
Rep: 1397 Posts: 7,215
Yes you can tell by the J tubes. In an automotive carb they are straight
Holley Carb Blues TollyWally Gas Engines 26 07-02-2009 04:21 AM
EFI vs Carb? diello Powerboats 33 10-30-2007 09:58 AM
Two Engins one carb madtech Gas Engines 42 05-31-2007 06:54 AM
carb problems ?? luny1 Outboards 1 05-08-2007 07:46 AM
Marinizing Holley Carbs - Gonzo? eddievanhalen DIY Marinizing 1 02-28-2007 06:14 PM
