  #121
Old 05-02-2009, 08:57 AM
kistinie's Avatar
kistinie kistinie is offline
Hybrid corsair
Rep: -74 Posts: 493
Your welcome, i am glad you got interesting thing to read searching the web !
May like this too
http://www.youtube.com/watch?v=XWhHC...eature=related
http://www.youtube.com/watch?v=Dfj1O...eature=related
Days of corrupted oils are numbered
  #122
Old 05-02-2009, 02:17 PM
mgriffin mgriffin is offline
Previous Member
Rep: 92 Posts: 122
You didn't get the reason I posted that simple simon poem, did you kistinie?
  #123
Old 05-02-2009, 02:24 PM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,252
Originally Posted by mydauphin View Post
Something that might actually fit in this thread.
the alternator in my truck (200amp) went bad. After replacing I kept core to experiment. I realize that voltage regulator went bad. I bypass it and this thing is know putting all kinds of power, upwards of 30 volts and I dont know how much amperage. It seems higher voltage is feeding Alternator field and making even more power. If I hook it up to charge regulator like the kind OUTBACK uses for solar panels I can convert those high voltage back 12volt without losing to much efficiency. Anyone have any comments on this idea. Ultimately , it want to run this via windpower in my farm...
Congratulations, you have discovered the function of a regulator. Without your bypass it supplies just enough energy to the rotor to obtain the rated output in a 12 volts system. If the output voltage rises above a certain threshold (around 14 volts), the output is reduced to nearly zero.
With the regulator terminals bridged you get an open voltage over 30 volts and maximum current the alternator can handle. Used like that in a 12 volts system, the battery will start boiling until it is dry, then the system voltage will rise so all connected devices will burn out. Unless of course the load it high enough to keep the voltage within boundaries, in which case the alternator will eventually commit suicide because it is not designed for the thermal load.
  #124
Old 05-02-2009, 02:26 PM
Previous Member
Rep: 92 Posts: 122
did you get the reason I posted the simple simon poem?
  #125
Old 05-02-2009, 05:55 PM
apex1
And this is what Kistinie wanted instead of a Diesel propulsion.
Or, lets say, what he should have wanted, instead of nonsense.
http://www.ozmarine.se/OZecoDrive/En...oDriveEng.html
  #126
Old 05-02-2009, 10:35 PM
Rep: 527 Posts: 792
May like this too
You know a thread has "jumped the shark" when the water powered car comes out
http://www.treehugger.com/files/2008...-debunking.php
  #127
Old 05-02-2009, 11:56 PM
kistinie's Avatar
Hybrid corsair
Rep: -74 Posts: 493
Water Level ...
Just look at facts
the more we study water the more power we get from it. No legend or urban myth.
Level one : Direct water injection to ICE
Result : More power when added to inlet(increase power, limit detonation) and outlet (cools & accelerate)gas
Level 2 : Cracking water in H² and O² and adding to inlet of ICE engine
Result ; Much more torque and power when added to inlet, cleaner combustion
Level 3 : Full Water engine using only H², O², reacting on metals and other physical effects to understand better.
Tesla free energy, Bedini motor, joe cell and other experimentations are unexplained.
Just like we can't explain black holes, dark energy...the list is long.
For propulsion, water seems to have more potential, at least used with metals, just like for aluminium-gallium producing H²
So here it is a water/metalic fed car :-)
Of course it is not water alone ! For the moment ;-)
But metals in water or bacteria in water...no more oil
So once again facts show that in the futur
Oil will remain great to product carbon fibre, plastics, ... and aramide, but not to burn
  #128
Old 05-03-2009, 12:14 AM
Rep: 527 Posts: 792
Result : More power when added to inlet and out let
Result ; Much more power when added to inlet
Level 3 : Full Water engine using only H², O² and other physical effects to understand better.
Oil is great to product carbon fibre and aramide
Level 1
Water injection is useful as a replacement for 'power enrichment', which normally uses the fuel as an evaporative coolant to reduce combustion temps. Since the engine is burning rich of stoichiometric under such enrichment, this extra fuel will not be burned, but act only as a coolant. In this regard, water injection can reduce fuel consumption under some circumstances. The need for power enrichment has been greatly reduced by the advent of EFI and the intake manifold designs that EFI allows. Either way, there is no magic here.
Level 2
The cracking of H20 always requires more energy than can be recovered in subsequent combustion. This includes catalytic metal reactors since the reactor catalyst material will become quickly depleted and must be replaced. The manufacturing of these represents the unrecoverable energy loss in this case. Again, there is no magic here. If you could mine the catalyst material from the ground rather than manufacture it, then maybe there's some sleight of hand. Still no magic, but at least a nice illusion of magic.
Adding H2 to the air stream of an ICE that burns another primary fuel is simply way to 'fool' an EFI setup into running the engine lean. Note this only works with an EFI equipped engine, meaning that it's not a primary effect. This is certainly not magic.
Level 3
But water does not burn. In fact, I'm told they often use the stuff to extinguish fires. Cracking water is energy net negative, as I've explained. At best, hydrogen can become but an energy storage media, like a battery, storing energy that is invested in it during cracking. Definitely not magical.
Jimbo
  #129
Old 05-03-2009, 01:21 AM
kistinie's Avatar
Hybrid corsair
Rep: -74 Posts: 493
Magical mystery tour ?
This is not a magician forum of course nothing magic
Water injection give a lot of improvements much more easily than by other complicated devices.
Engine can get simpler with increase efficiency when water injected
When craking energy to get H² and O² is coming from solar panels, bacterias, metals...some oil is saved for a better use.
But this is already the past
New solution will rely on new physical effect we do not understand for the moment.
And when 100.000 individuals search, answer will be found kicker...thank's to the basic statistics laws !
This is the force of internet
Global thinking
Individual actions
And such research organisation is very powerful to break lobby and corruption
Learn, study, test and give feed back to the others.
The JP MORGAN collapse is a destiny reverse that may re-open our eyes on Tesla 's work ?
  #130
Old 05-03-2009, 01:32 AM
masalai masalai is offline
masalai
Rep: 1689 Posts: 7,510
kistinie, wishful thinking will not fix anything - look at the impact of the American (USA) fiscal collapse on the global economy, No amount of wishing will resolve or fix that - and it seems your desires follow along on a similar vein.... One cannot get blood from a stone - except maybe, from stromatalites which grow in just two parts of the world...
If you listen to nothing else this weekend - hear this - and figure out how to fend for yourself... http://www.financialsense.com/fsn/main.html - go to "3rd Hour with Jim & John - - Select an Audio Format - Part 1" and select the audio file type you prefer (all are the same content in audio files and in American English)...
Try to be helpful...
Remember that there are at least two sides for every story...
  #131
Old 05-03-2009, 04:32 AM
Rep: 501 Posts: 1,767
kistinie, you must be from France.
When you go to the baker does he give you bread for free.
The wheat is cheap, it comes from solar energy.
But it has labor, he needs to support his family, his mistress.
and if he adds too much water to flour the bread is no good....
Same with engines, energy, laws of economics, physics....
Go back to school and study physics, economics, thermodynamics, friction.
  #132
Old 05-03-2009, 04:47 AM
apex1
I´m shure he still is at shool Mydauphin (3rd grade).
  #133
Old 05-03-2009, 05:20 AM
kistinie's Avatar
Hybrid corsair
Rep: -74 Posts: 493
La parabole du boulanger...
Why not ? Nothing else more solid to explain us how what i say is junk science ?
I admit i am a curious item, but the subject is not me, subject is producing power for motion and electricity in a clever and responsible way, not a totalitarian destructive way like now with petrol.
Please let us play alone with our child games while you fill up your tank with oil and the cows will be happy.
As it doesn't work we will stop playing very soon ?
So why do you worry for this ?
  #134
Old 05-03-2009, 08:40 AM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
Indeed, Jimbo..... but remember, a thread isn't OVER until Godwin's Law is satisfied.
  #135
Old 05-03-2009, 10:12 AM
kistinie's Avatar
Hybrid corsair
Rep: -74 Posts: 493
Azerty ...Qwerty . Dvorak and other killed good ideas
All the attitude toward new systems, more efficient look like the new (1936) DVORAK layout for PC keyboards allowing more word per minute in most language, but impossible to set in because of "habitude"
http://en.wikipedia.org/wiki/Dvorak_Simplified_Keyboard
Propeller Gear + Efficency FAST FRED Inboards 5 04-11-2008 08:31 PM
Marine generator BustedKnuckle Electrical Systems 11 11-23-2007 08:01 AM
High voltage DC generator prp25brad Electrical Systems 15 06-02-2006 08:55 AM
generator installation Wild Bill Electrical Systems 0 02-16-2006 07:53 PM
Portager's Generator Portager Electrical Systems 0 07-24-2003 12:19 AM
