Old 01-12-2011, 01:57 PM
Lowhorsepower Lowhorsepower is offline
Rep: 10 Posts: 10
Thanks!
Old 01-13-2011, 06:35 AM
Boston's Avatar
Boston Boston is online now
Rep: 1457 Posts: 3,355
Nice Job LowHorsePower
that set up is really well done
do you have any full body shots of that boat
I'd sure like to see the whole thing
cheers
B
Hey Gonzo
whats that bit about ignition protected
I wasn't aware of a difference between an alternator for a diesel and an alternator for a gas engine
I am skeptical of the deniers diatribe
Old 01-13-2011, 11:27 AM
Rep: 10 Posts: 10
Here are a couple of pics, kinda hard to get a good shot in my shop. The alternator is not a marine type that is sealed to prevent an explosion in a true inboard.
Old 01-13-2011, 12:07 PM
Boston's Avatar
nice
you did a really clean job in converting it to power
Old 01-13-2011, 02:41 PM
Rep: 10 Posts: 10
Thanks!
Old 03-07-2011, 12:10 AM
Pandoras box Pandoras box is offline
Rep: 10 Posts: 11
Lowhorsepower,
Did I read in another post that you change the engine and alternator out? If so do you have any specifics go howl and why? Thanks, Mike
Old 09-14-2011, 09:36 AM
gonagin gonagin is offline
Rep: 15 Posts: 4
Kudos
Kudos to you sir!!! Nicely done, very professional looking and the fact that you recycled and saved an old boat gets you double kudos!!! It won't end up rotting on a mud flat somewhere for someone else to clean up.
Old 09-15-2011, 12:19 PM
Dave T Dave T is offline
Rep: 67 Posts: 56
Lowhorsepower
I'm in the process of building a home made boat and I'm considering using a briggs for power. I have two 12 horse and an 18 horse available these are all vertical shaft and I plan on using the lower unit from an outboard. I'm also considering using an electric outboard on the front for silent running and emergencies if a failure would happen with the gas engine. I'm thinking of a motor from a golf cart for this. I've already built the lower unit consisting of a tube bored to fit two tapered bearings for thrust a mechanical seal and a chain drive up through an enclosed tube that runs in oil. To keep the electric motor cool I'm thinking of wrapping it with copper tubing and pumping water through it.
What size is your boat and do you know how much it weighs?
Nice work,
Dave T
Old 09-21-2011, 04:17 PM
ben2go ben2go is offline
Boat Builder Wanna Be
Rep: 13 Posts: 136
Bump for a good read.
High Efficency Crusier, Trike or Tri? Zenehet Boat Design 9 05-26-2009 01:23 PM
catfish beach crusier or nancy's china? dogfuel Sailboats 0 07-28-2008 07:35 PM
Tonka Motor Crusier 12m harveybowden Boat Design 1 03-01-2007 03:00 AM
How Many Horsepower Can I Have ? VKRUE Boatbuilding 9 04-08-2006 01:51 PM
Low power tunnel, low speed drive robrohdeszudy Propulsion 9 12-23-2004 04:09 PM
