Old 04-17-2009, 05:50 PM
licensedtochill licensedtochill is offline
Rep: 11 Posts: 3
Longtail motor angle
First timer here-- great site. Building a longtail motor with a 6.5 hp clone engine. According to briggs and stratton website the maximum angle for proper motor operation is 15 degrees. Due to my design i need to run motor at 20 degrees. Is the going to be problems with this? Can i add more oil to crankcase to compensate? carbuerator issues? Thanks for any replys.
Old 05-01-2009, 01:56 AM
pistnbroke's Avatar
I try
Rep: 372 Posts: 1,230
have a look at my post " thai longtail with 6.5hp lifan/honda" you will also find posts on larger engines than weed eaters in the weedeater post...some use a universal joint so the engine is basically horisontal ..but you need a good joint !!!
Old 05-01-2009, 08:49 AM
mudman mudman is offline
Rep: 72 Posts: 88
Agreed. Heavy duty U joint. Keep is properly greased.
Old 05-01-2009, 05:04 PM
peter radclyffe's Avatar
peter radclyffe peter radclyffe is offline
Rep: 561 Posts: 1,052
if possible get a down angle gearbox, if its a launch this angle may get worse as the bow lifts
Old 05-01-2009, 05:05 PM
but sure get a truck u.j to keep cost down
Old 05-01-2009, 09:19 PM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1514 Posts: 5,518
On a real long tail,--and I can hear one passing by me now --the engine is fastened straight to the shaft after being geared down by approx8:1
The whole thing is on swivel,--up down and 360 degrees for reverse.
when not in use you park the prop on the bow post where it keeps clean and the engine then drip oil over the transom.
Theres is so much to be admired from this simple system.
ALL parts for this including engines can be bought over the counter at most hard ware stores.
UJ? where does that go?
10M Thai Long Tail
Old 05-01-2009, 09:27 PM
Rangerspeedboat Rangerspeedboat is offline
Rep: 17 Posts: 120
Most go devils have u joints inbetween the engine a prop shaft.
Look at this pic, you can see the u-joint near the engine
http://godevil.com/Images/6.5Intekenginelarge.jpg
Old 05-01-2009, 09:43 PM
pistnbroke's Avatar
I try
I think if you look at that go devil the metal work is complex compaired to my chain drive design ( which also gives you a right hand prop) I think 20 deg is a bit high 15 more like it ....and whats this about the bow comming up ..it on a swivel joint ....if you have a "cavitation plate " over the prop it will always stay at the same depth in the water ...ie rig for cavitation plate to be horisontal ..15 deg to shaft....I think 8 :1 is a bit high for a 5 hp the driven gear will be very large dia ..mine is 2:1 and drives a 9 x 10 pitch..I trust you checked the photos in diy marinising
Old 05-01-2009, 11:34 PM
sorry guys, i misunderstood what a longtail is there, it is also used to describe a type of launch stern, ignore my post, the uj is unusable, & the bow up or down is irrelevant
Old 05-04-2009, 06:06 PM
Rep: 72 Posts: 88
Everybody likes their longtail a different way. There are many different ways to make one. I personally like em 1:1 directly coupled to the engine shaft with a cutlass in the water. Drill a few holes in the shaft tube for lubrication. Sit em as low as they go on the transom. 5 hp engines are easy to come by and we run em hard. An engine may last 3 years, if it's lucky.
I've seen em with u-joints too. First time I've seen a chain pistonbroke. Good way to get a better angle though. U-joints wear out, but it takes a few years. They are not designed to take the linear force.
Old 06-28-2009, 04:12 PM
John O`Neal John O`Neal is offline
Rep: 29 Posts: 85
I was recently watching a National Geographic program about the undiscovered tribes of the Amazon. To my great interest the preferred means of travel, in that remote area, were boats powered by long tail Mud motors. The motors were very simplistic in design. The drive shafts were directly connected to the engine (no U-joint) thus requiring the engine to be tilted downward when dropping the prop into the water. A fairly short boom on one of the boats required the motor to be tilted at an estimated 20-degrees+ when operating . The engine appeared to handle this tilt angle with no problem what so ever. The engines based on size and color appeared to be possibly Honda Gx 160 or 200`s. After that show I consulted with Dennis Scott of Scott Racing engines . Dennis builds ,dynos, and sells a lot of these type engines. I brought up my concerns about tilting the engine up to 25 degrees when operating. Dennis expressed confidence that angles approaching 25 degrees were acceptable . He did recommend adding a little extra oil to the crankcase though. I wouldn`t hesitate, tilt it and go.
Old 06-28-2009, 04:29 PM
Rep: 29 Posts: 85
Mudman ; I admire the simplicity of you design. You stated " Drill a few holes in the shaft tube for lubrication" Could you be a little more specific. Are you using water as the lubricant ??
advice on Thai Longtail boat project napalmtheelf Projects & Proposals 36 03-02-2011 10:26 PM
Longtail thailand tabanaza Boat Design 0 04-15-2009 08:57 PM
Skid Fin Angle or not to Angle? dcrummett Powerboats 2 06-11-2008 04:29 PM
weedeater longtail caveman DIY Marinizing 8 10-01-2006 06:32 PM
Relationship between angle of attack of keel and heel angle stelios Sailboats 9 05-29-2006 03:14 PM
