| Long Tail ..a question of balance I am putting together a long tail powered by a 6.5 hp Honda and my question is how do I deteriming the piviot point ...Logic would say point should be forward of the balance centre so the prop sinks but how much and am I right ?? |
| A few photos.. from Bangkok Quote:
Balancing a Turbocharged 6 cylinder diesel (the largest I saw) is not child's play!! These are amazing boats.. Small LongTail: http://www.terryking.us/photoalbum/v...10766.JPG.html Pivot Points and drivers: 4 Cylinder diesels: http://www.terryking.us/photoalbum/v...08/?g2_page=11 A closer-up of the pivot. SEEMS adjustable! http://www.terryking.us/photoalbum/v...geViewsIndex=1 Other weight-distribution example: http://www.terryking.us/photoalbum/v...60047.JPG.html The whole album here: http://www.terryking.us/photoalbum/v/travel/bangkok08/ I'd love to build one of these some time with an aluminum-block V8 :-) HEY! Show us a photo of yours when you're done!
| Thanks for that Terry ....I deduce Limit on downward movement of tailshaft even if it only hits the boat transom. seem to retain gearbox and control of the lever ...anyone seen one go in reverse ?? Uses the clutch the mounts would indicate slightly tail heavy but not much.. Well I have the centrifugal clutch and got the tail pipe/shaft and bearings yesterday . Have engineered the prop end with a taper roller bearing and oil seal so the job is moving...My shaft goes under the engine with a 2.11 chain drive so I can have a right hand prop ... |
| Small Aircooled Engines "Marinizing" While we're at this: Can anyone ID this engine I recently saw used in small boats on Mabul Island off the East coast of Borneo?? They seem to work pretty well in these small (12 foot or so planing boats). The Engine: http://terryking.us/photoalbum/v/tra...ts-34.JPG.html A boat on plane: http://terryking.us/photoalbum/v/tra...ts-40.JPG.html More boats: http://terryking.us/photoalbum/v/tra...ats/?g2_page=7 The whole album: http://terryking.us/photoalbum/v/travel/borneo2009/ (Click on any photo for larger; click again for even bigger) These guys spend most of their time building, fixing and running boats, and fishing. I think I could live there!
| Looks like the 13 hp copy of the honda ..I think its Lupin or similar brand I have the 6.5 hp version dond see the point of extending the shaft so far behind the boat as you would only draw more water..better under the boat ...like the offset rudder anyone out there built and balanced a longtail |
| yep You certainly want to ensure that the longtail, when unattended, sits with the prop in the water. How much force is erquired to lift it out of the water is a personal preference. I've seen first hand what happens when the motor is balanced with the prop out of the water when unattended (my first mud motor build). I did not have a clutch on this motor either. Combination of the two was a horrible mistake. I started the motor and pushed the boat off the shore. As I got into the boat, the motor swung around and the spinning prop almost hit me in the head. I've been told I have a hard head and all but I think the prop would hitting my head would have made short order out of me.. for what it is worth. Mark |
| Latest Thai Long tail boats Hi, I am living in Thailand and my hobby is to build long tail boats and tune Honda engines. I would like to share the long tail setups presently available here. The engine shown, is a new model of the 6.5hp engine from Honda with Digital ignition and "Marine" compatible parts. The governor is removed and the ignition has a limiter at 4500 RPM. the idle can go down to about 800 RPM with the special carb setup and the camshaft used. the complete setup costs here about $400.- so no need to have headache with home R&D. The equivalent setup with a 13hp engine is around $650.- |
| Hi, Please visit our website of Thai Manufacturing of Long tail propeller. We can support your requirement in some part. Our website is www.longtailboatsps.com |
| Hey, just buy one and have it sent home, thanks for the info.
| The true longtail was the Yanmar industrial deisel chug chug chug with black smoke and plenty of noise. The bigger 6 cylinders are the Hino E700 a lovely engine resembling a Ford Lehman in red as well. Some of them are dressed in chrome injector pipes pulleys etc etc I have some photos taken through the rail way lines of the Bridge on the River Kwai When on the plane there appears to be no effort required, there fore the upward thrust of the surface prop would suggest that some considerable force is allowed to counter act that. The weight used to push the engine down and the prop up --looks--- to be about --say--6 to 8 kilo looking at the effort required by the small figure of a Thai. Some one asked reverse?? they don't -you swing the thing all the way round till the prop is a beam. Very versatile really. |
| Because the drive shaft is on an angle the decending prop blades should pull the drive down into the water even at speed that is what happened on my trimmable drive which was free to move up or down.
__________________ tomkane |
| Longtail engines from Thailand Tom I was wanting to call you and have a chat, you remeber me Stephen Snedden i was making allooy barges before folding type, |
| Long Tail ..a question of balance Hi Stephen, I often think about you and MYARK and often when I need a quiet pick-me-up I watch the video I have of the trip to Waikeremoana Lake as it gets me back to my boating and camping trips. I still live same address in Hillcrest Hamilton. You can get e-mail contact to me through this website. It would be great to have a chat.
| Ruraint & long tail moter? | plymouth | Open Discussion: All Things Boats & Boating | 5 | 12-05-2010 08:44 AM |
| 10M Thai Long Tail | S.E.A. | Post-Tsunami | 44 | 06-21-2009 12:00 AM |
| Relationship between keel shape and rig balance question. | quilbilly | Sailboats | 4 | 09-25-2007 04:16 PM |
| Long Tail Boat Designers | Konrad Marine | Boat Design | 2 | 03-15-2006 02:56 AM |
| Long tail boat propelsion | VISHNU PRASAD | Propulsion | 2 | 01-06-2006 01:27 AM |
