Old 08-17-2011, 12:10 PM
Jeremy Clarkson Jeremy Clarkson is offline
Rep: 19 Posts: 25
Lawn mower engine outboard motor?
I have a really nice new electric start 6.5 hp lawn mower engine.
But it is vertical shaft.
Is there like a 90 degree elbow gearbox thing I can buy that I could bolt to the shaft that would make it so I could put a horizontal propeller on it.
I've seen something like this for drills where for getting into tight places the drill mounts to a 90 degree transfer and then you can drill things bent
what is this called?
what about using a chain?
Old 08-17-2011, 12:12 PM
CatBuilder CatBuilder is offline
Rep: 1316 Posts: 3,040
I'd be VERY interested in one of these as well. Some other uses for them.
Kurt Hughes was right about this place.
Old 08-17-2011, 12:19 PM
Rep: 19 Posts: 25
yeah I cant find what I'm talking about because I have no idea what it's called
Old 08-17-2011, 12:28 PM
I believe it's called a 90 degree drive.
Check these out. Answers two of your questions at once!
http://www.model-dockyard.com/acatal...ve_Motors.html
Old 08-19-2011, 02:32 AM
pistnbroke's Avatar
I try
Rep: 387 Posts: 1,269
sorry are you missing the point .....a right angle drive ..its called an outboard leg .....you get reverse too ....
Lawn mower engine outboard motor?-brigsazooki-002.jpg  Lawn mower engine outboard motor?-brigsazooki-001.jpg
Old 08-19-2011, 12:11 PM
Rep: 3125 Posts: 9,399
Agreed, you can turn the output on a vertical shaft engine to horizontal if you want, but the wise fabricator just uses a horizontal engine in the first place and eliminates the need for the 90 degree leg, not to mention the power loses that come with it.
I've used live axles from cars to make this setup on rare occasions, just remove one of the axle tubes and weld it closed and U joint the thing to what ever you're attempting to drive. The last one I did was many years ago and I used a small Ford rear. It worked, but was noisy and heavy.
Old 08-19-2011, 02:35 PM
pistnbroke's Avatar
I try
have I missed something this is only 6.5 hp and he wants a propeller ...so fit it on a leg ..????/
Old 08-19-2011, 06:58 PM
Piston, I think he wants to make a straight shaft setup, but use his vertical lawn mower engine, which is an interesting choice in itself. It could be done, but after you count up the loses from the output direction change, you'll be lucky to have 4 HP at the prop.
Old 08-19-2011, 09:03 PM
Dirteater's Avatar
Dirteater Dirteater is offline
Rep: 187 Posts: 151
http://powertoolslink.com/_cache/Har...0Tools_0_1.jpg
something like this?
thinking about putting tholes in my boat.
Old 08-19-2011, 09:07 PM
Mr Efficiency Mr Efficiency is offline
Rep: 246 Posts: 711
The noise of an air-cooled engine is wearing, IMO.
Old 08-20-2011, 12:20 AM
Rep: 19 Posts: 25
Yes exactly like that picture
How would it lose that much power?
I want to do this because I have nothing else to do with a vertical motor
Old 08-20-2011, 12:47 AM
pistnbroke's Avatar
I try
Vertical shaft motor = outboard
Horisontal shaft motor = longtail
If you go with either of the above you can KISS and cheap But is the last S the problem ?
Suggest you google mud motors which have horisontal shaft motor and various means of driving the prop ....V belts etc
Old 08-20-2011, 01:45 AM
FMS FMS is offline
Rep: 125 Posts: 233
Your idea of using an outboard leg for a DIY isn't stupid at all. It's been done a number of times.
The OP has a thread about a light kayak hull and mentions wanting a shaft here.
Maybe he can tell more about the boat this DIY setup is for.
Could always trade it to someone who has nothing else to do with a horizontal motor Often cheaper than monkeying around trying to make a square peg fit into a round hole.
Old 08-20-2011, 01:56 AM
pistnbroke's Avatar
I try
FMS I know I am not stupid ..but if its a light Kayak this thing is too heavy anyway.
unsubscribed ....there are non so blind as those who cannot see ....bye
Old 08-22-2011, 12:15 AM
Harpo Harpo is offline
If your engine is designed for a walk-behind lawn mower, it will not run properly without a blade. The flywheel on walk mowers is light aluminum, and the engine needs the mass of the blade to act as additional flywheel weight, carrying the rotation through the exhaust/intake cycle.
There are some vertical shaft engines with a heavy flywheel - these are used on riding mowers and tillers.
If you're not sure, try and start it without a blade. If it kicks back and pops, or tries to drag the starter rope back in, it's a light flywheel!
Electric lawn mower into outboard motor? aannjj Propulsion 2 07-12-2007 03:43 PM
Lawn Mower Outboard sonycrayfish DIY Marinizing 4 04-17-2007 01:26 AM
how do i build a boat motor with a lawn more engine jchronister3468 DIY Marinizing 13 07-14-2006 12:09 AM
lawn mower boat DIY Marinizing 19 09-22-2005 09:19 AM
lawn mower outboard conversion kenfyoozed Propulsion 3 05-06-2005 09:16 PM
