Old 08-22-2011, 02:06 AM
pistnbroke's Avatar
I try
Rep: 387 Posts: 1,269
if you look at post 5 you will see that it works fine with a B and S that one was a 3.5 HP but not a bad idea to try it without the blade ...
Old 08-26-2011, 05:31 PM
MengWalton's Avatar
MengWalton MengWalton is offline
Rep: 26 Posts: 33
I haven't reli got a clue when it comes to small engines like these (except model nitro's) But cant you just lay the engine on its side, then there's no need for any 90^o angle transmition.... just a thought
John
Old 08-26-2011, 05:36 PM
Chase_B Chase_B is offline
Rep: 76 Posts: 53
I believe the "Mud Puppy" uses a horizontal shaft engine with belt drive down to a jet pump,..so scrounge for a jet ski pump and build the "shaft" ( housing for a belt) to the depth you need
just a thought
Old 08-26-2011, 07:12 PM
masalai masalai is offline
masalai
Rep: 1689 Posts: 7,510
I just realised, I have lawn-mower engines on my boat (a pair of Kubota (Nanni sail-drives), same 20hp diesel engine as used on a larger ride-on mower
Try to be helpful...
Remember that there are at least two sides for every story...
Old 08-30-2011, 12:38 PM
Easy Rider's Avatar
Easy Rider Easy Rider is offline
Rep: 694 Posts: 670
masalai,
How is vibration controlled on that type of drive? It would seem that all the vibration of the 2 or 3 cyl diesel would go undiminished right to the bottom of the boat turning it into a big drum.
Old 08-30-2011, 04:23 PM
Rep: 3125 Posts: 9,399
Eric, I just purchased a 14 HP unit just like the one pictured and it comes with a 'glass box, motor mounts, drive seal, everything. The 'glass box serves to hold the engine and drive assembly, both on rubber mounts. This is bonded in place, after being scribed to fit the hull and a hole cut of course. Once sealed and tabbed in, the box becomes part of the boat (regardless of build method) and the engine/drive assembly can be easily removed.
It solves a lot of problems and eliminates a lot of parts. No shaft, nor it's alignment, no strut or cutlass, no stuffing box, stern tube, etc. The leak potential is greatly reduced and the motor is a marine based unit designed to live in this tight package, so it has an on board oil pump out setup, filters, heat exchanger, etc. The 14 HP unit was available shipped to me (about 1,000 miles) for less then 9k which is quite reasonable for a nearly ready to install unit.
Old 08-30-2011, 06:58 PM
masalai
Thanks Par,
Well answered and I agree... Some sound does permeate because I have a large resonant surface, (bridge-deck floor), which will be fixed with the installation of a carpet...
My engines/saildrives came with the OEM kit which included those grp engine/beds, as well as ALL bits to install, including fuel lines, exhaust pipes, ss clamps, wiring harness and right down to a couple of small specialised tools... Au$33K for the pair when the Au$ was about 75cents US.... Not almost the other way round, like it is now at US$1.06... - - PS, those GRP bases are the same for the 2, 3 and 4 cylinder engines as are the legs (I think)? - I am looking for a pair of fixed 3 blade propellers to suit current is 15" x 11" pitch 2 blade folding, suggestions from a) Bob Oram is 3 blade fixed 14" x 13"pitch and from a supplier, 3 blade 15" x 11" pitch on a 17 spline 'shaft'... Any offers/information, please reply on my thread My little piece of peace
Old 08-30-2011, 10:24 PM
BATAAN's Avatar
BATAAN BATAAN is offline
Rep: 1090 Posts: 1,502
Lawn mower motor without right angle drive.
Old 09-04-2011, 02:50 AM
pistnbroke's Avatar
I try
and my version
  #25
Old 09-04-2011, 08:49 AM
BATAAN's Avatar
Very nice. Supposedly if some of the prop is out of the water in use, it is more efficient. I think it's called a Surface Piercing Drive and a fellow named Arneson made large modern use of it. A friend described doing 100 mph on the Petaluma river with him years ago.
  #26
Old 09-04-2011, 12:08 PM
pistnbroke's Avatar
I try
yes but a surface prop has to be designed not just any old prop sticking out the water ....heard of an anti ventilaton plate ( mate )
Electric lawn mower into outboard motor? aannjj Propulsion 2 07-12-2007 03:43 PM
Lawn Mower Outboard sonycrayfish DIY Marinizing 4 04-17-2007 01:26 AM
how do i build a boat motor with a lawn more engine jchronister3468 DIY Marinizing 13 07-14-2006 12:09 AM
lawn mower boat DIY Marinizing 19 09-22-2005 09:19 AM
lawn mower outboard conversion kenfyoozed Propulsion 3 05-06-2005 09:16 PM
