Old 11-20-2004, 06:16 PM
boat boat is offline
Rep: 10 Posts: 13
lawn mower
Dose any one know a way of adapting a lawn mower motor in to an inboard motor
Old 05-09-2005, 12:48 AM
tom kane's Avatar
tom kane tom kane is offline
Rep: 265 Posts: 865
lawn mower
This image may be of interest to you.The drive unit was made from a section of 4 inch galvanised pipe about 18 inches long with a plate welded about half way up so that when a hole was cut in the keelson the tube was sealed to keelson.Two water pump bearing from a vehicle were welded top and bottom and a chain connected the two bearings which had chain sprocket attached.
An exhaust pipe went down inside of the tube and welded at the bottom.The drive was used as a tractor propeller and was very good in this dingy with a lot of rocker in the rear end.A MK 10 Villers engine of 1 HP drove to a pully to the top bearing and the weight of the motor kept tension on the drive belt and could be used as a clutch by raising the motor.
tomkane
Old 05-12-2005, 05:57 PM
bsmit24 bsmit24 is offline
Rep: 10 Posts: 17
I have a small 14' fiberglass skiff that I would like to try something like that on. Do you have any other info about the setup or a website where I could look at someother pic/drawings
Thanks
Brian
Old 05-12-2005, 08:54 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
The big problem here is that a lawnmower engine has a vertical shaft, a boat propshaft is usually horizontal. To use the mower engine to turn a prop, there needs to be a 90-degree gearbox somewhere. Running a mower engine turned on its side will do some pretty hefty damage to its innards. You can easily adapt them to outboards; Briggs&Stratton even sells one of their mower engines with an outboard leg and bracket attached. The only production vertical-shaft inboards I've ever seen are Merc O/B powerheads tacked onto jet drives.
No real reason why you couldn't try though. Perhaps use the lower gearcase of an old outboard, bolt it on the undersde of the hull with the shaft coming up through the hull, stick the mower motor on top of that? Just a thought....
Old 05-13-2005, 08:59 AM
Rep: 10 Posts: 17
I think Glen L has a conversion for a vertical shaft and an old outboard leg. It uses pulleys so that you can run a larger prop. I might try that if all else fails. I could not find a sutible prop that would work.
But I have an 12.5hp horizontal shaft that I wanted to use.
Old 05-14-2005, 10:38 PM
kmorin kmorin is offline
Rep: 230 Posts: 185
marinized lawn mower engines
bsmit24,
about 20 some years ago there were ads in the back of National Fisherman and some other marine periodicals that offered various 'designs' to use Briggs engines both horizontal and vertical in boats.
In each case I think these applications used cog belts or rubber toothed belts like timing belts because they'll transmitt hundreds of horse power and are tolerant of line up error. I saw one of the brochures and it essentially used off the shelf pulley wheels and bulkhead mounted bearings with common shaft hubs to reduce the full speed RPM down to shaft speed.
The horizontal applications arranged the engine above the shaft and drove the shaft by and offset cog belt. The shaft pushed and pulled on a double cone bulkhead mounted bearing -like Fafnir makes.
One design used the bottom end of an old outboard by cutting through the aluminum casting of the leg and tapping the face of the casting for a bearing that stablized the cut off vertical shaft. This had a vertical shaft engine coupled to the top and the leg could not pivot- it was fixed like a keel boat.
I recall the designs were a few dollars each and were mailed from Maine or somewhere in the NE. They were plenty innovative and looked like they'd move a small skiff.
One very interesting application was a centrifugal pump that was made by welding some sections of large diameter pipe to a set of round plates and included a means to drill out the plates and balance the entire impeller. This unit was powered by vertical shaft motors and was teh pump housing was bolted to the bottom of an aluminum riveted skiff about 14' long. The tiller moved a "jet nozzle" and the tiller rod bolted to the transom of the skiff.
I have no idea if these pamphlets are still for sale or who the author/inventor was. They made no provision for exhaust cooling that I recall.
Sounds like a fun project, shouldn't be too hard to rig up -I think the shaft log & seals for a conventional shaft arrangement would be the most complicated in a small boat. If you used parts of an old outboard then most of the running gear is already marined.
Cheers,
kmorin
Old 05-20-2005, 04:30 AM
Machnumber2 Machnumber2 is offline
Rep: 10 Posts: 7
hardware store parts made outboard
http://machnumber2.50megs.com/photos.../outboard.html
please email me if you have done anything like this
Rep: 10 Posts: 7
forgot my email, cgw993@aol.com
Old 05-24-2005, 08:01 PM
PowerTech PowerTech is offline
Rep: 4 Posts: 183
http://www.mlengine.com/new_page_13.htm
Old 05-27-2005, 08:12 PM
SamSam SamSam is offline
Rep: 464 Posts: 1,607
This probably isn't what you meant but it's sort of an inboard and it did work.
Old 05-27-2005, 10:12 PM
tom kane's Avatar
Rep: 265 Posts: 865
Hey that is great,and you should see some of the modern concepts for high speed work.
tomkane
Old 05-28-2005, 09:08 AM
If you were referring to paddlewheels, I would like to see anything new about them. Sam
Old 05-28-2005, 07:53 PM
tom kane's Avatar
Rep: 265 Posts: 865
Hi Sam,if you take a look at the thread Modern paddelwheels some ideas abound.
tomkane
Old 05-28-2005, 11:21 PM
Rep: 10 Posts: 7
That is fantastic, nice work! How fast does it go, and do you have trouble with the belt slipping?
Old 05-29-2005, 02:51 AM
tom kane's Avatar
Rep: 265 Posts: 865
If you use all of the outboard as is,that is the motor,leg and gearbox there are no belts to slip.A simple model goes well and can grind through the shallows.Add wheels to the boat there is more fun.A fast model would need to be well engineered and there is a lot to learn with this type of propulsion.
tomkane
how do i build a boat motor with a lawn more engine jchronister3468 DIY Marinizing 13 07-14-2006 01:09 AM
lawn mower outboard conversion kenfyoozed Propulsion 3 05-06-2005 10:16 PM
