Old 05-30-2005, 05:24 PM
SamSam SamSam is offline
Rep: 464 Posts: 1,607
Originally Posted by Machnumber2
That is fantastic, nice work! How fast does it go, and do you have trouble with the belt slipping?
Mr. Mach2, I'm not sure to who or what you are referring. Tom, when I find the modern paddlwheel thread I'll post something I found at the USPTO site. Whoever invented it sure thinks it will be high speed. Sam
Old 05-30-2005, 10:12 PM
tom kane's Avatar
tom kane tom kane is offline
Rep: 265 Posts: 865
thanks,will look forward to that as I find it an interesting subject.
tomkane
Old 08-07-2005, 07:30 PM
maxwell maxwell is offline
redneck
Rep: 10 Posts: 3
I looked into building A simple V drive with two shafts, two pillow blocks, and a U joint to get the 12 degres out the bottom. It is very posible for about 100$.
Old 08-16-2005, 08:07 PM
rvBilly rvBilly is offline
Rep: 10 Posts: 14
V-Drive
This sounds very simple, do you have any plans or pictures of this homemade drive, I want to use a snowmobile engine in a small 11 foot speed boat, but am having problems trying to find a plan or picture of such a v drive, thanks Bill Pickering rvbilly@shaw.ca
Old 09-22-2005, 10:19 AM
Bowbender8 Bowbender8 is offline
Hartley in NZ has a design named Spearfish 12 which shows a simple IB based on a lawn mower engine. Glen-L designs has a very good book on the subject of Inboard engines for the homebuilt boat.
Key seems to be being careful to not create a problem with gasoline fumes gathering to explode. Most seem to be direct drive, no reverse and often no neutral, so one must use a trolling motor, paddle, or oars for docking.
In my opinion, good exhaust muffling is also important to make the modest cruising pace enjoyable.
how do i build a boat motor with a lawn more engine jchronister3468 DIY Marinizing 13 07-14-2006 01:09 AM
lawn mower outboard conversion kenfyoozed Propulsion 3 05-06-2005 10:16 PM
