| Kubota Z482 (13hp) marinization Hi, Here's my situation: 25.5 foot, 2 ton, racer/cruiser fibreglass yacht needing repower. (In New Zealand - that's the one below Australia for the geographically challenged) Problem: Low budget! I currently have an MD5B volvo with MD110S sail-drive, which is quite ancient and am thinking it will need replacement sooner rather than later. Having done my research I found that Beta and Nanni both supply an ideal light engine with perfect output (couple extra hp over current) based on the Kubota. Whats more, both offer a adaptor to mate up to the existing sail-drive which I very much want to retain. Also the standard gearing can be used, as the newer engines put out their higher power at higher RPM (Power/RPM curve same as Volvo, just longer). The catch is the cost. The above options are close on 10k NZ dollars (about 5k USD). I have recently spotted the standard Kubota Z482 for under $5K NZ (about 2.5k USD). So my natural question is, should I attempt marinization myself. I am fairly capable with motors, having done a few partial rebuilds etc, so don't mind tackling the labour myself. The questions are: Will I save reasonable money? What is needed outside the obvious, like water-water heat exchanger (current engine is raw water cooled), custom exhaust manifold pipe with water injection point (basic, compared to bigger engine systems), and a custom adaptor to the sail-drive/gear-box? At the end of the day, what differs from the off the shelf Z482, to the Beta marinized version? Look forward to some knowledgable replies! |
| Diecon engineering in Brisbane does a kit for A$2350 +617 3390 8190 info@diecon.com.au I have no experience or affiliation with them, just found them while doing some research on building a dc genset cheers John |
| Auto engine marinization | DIY Marinizing | 227 | 03-01-2009 07:00 PM | |
| DIESEL TRUCK engine Marinization | FAST FRED | DIY Marinizing | 31 | 07-07-2006 02:26 PM |
| Ford 1600cc crosflow marinization | John Mason | DIY Marinizing | 5 | 11-12-2005 01:42 PM |
