Old 01-17-2006, 08:12 PM
arvi arvi is offline
Rep: 10 Posts: 4
How to design a diesel engine?
I am supposed to find information on how to design a diesel engine for a small fishing boats. i need articles or papers or procedures in engine designing. Effective horsepower is 15hp. i have to design the gearing and shafting. but prior to that, i wish to see how an engine drawing look. Right now, I have a very vague picture on how to start designing or drawing. help is very much needed. Thank you.
Old 01-18-2006, 02:11 AM
zerogara's Avatar
zerogara zerogara is offline
build it and sail it
Rep: 64 Posts: 142
Not that hard actually, just sketch it out in your kitchen table and built it. I'm sure it will work!
Are you serious? You've never seen a drawing but you want to design an engine and transmission.
Old 01-30-2006, 04:16 PM
SamSam SamSam is offline
Rep: 455 Posts: 1,606
Now I understand how it saves American companies so much money to outsource. Sam
Old 02-02-2006, 07:26 AM
Rep: 10 Posts: 4
How to design diesel engine
I have stated the wrong terms actually. I have seen many engine drawings but not much systems drawings. What I need is a propulsion system drawing using diesel for a small fishing vessel. This is actually my undergraduate final year project. So, comparing to most of you, my knowledge on this would be quite shallow. I need some systems drawings of the propulsion system and the transmission for validation and a better view since my sources in my university is quite limited.
Old 02-02-2006, 08:46 AM
zerogara's Avatar
Rep: 64 Posts: 142
aRVi
http://www.merequipment.com/Transmis...rine_trans.htm
http://www.google.com/search?q=hurth...al&sa=N&tab=iw
Click and do a search on Hurth ZF and you may find something.
"People demand freedom of speech to make up for the freedom of thought which they avoid."
Soren Aabye Kierkegaard (1813-1855)
Old 02-02-2006, 08:47 PM
Arvi, these first two sites...
http://www.fao.org/documents/show_cd...e/ad944e00.htm
ftp://ftp.fao.org/docrep/fao/field/0...e/ad531e00.pdf
are from here...
(This won't print out. To get it, put "engines" in the search box in the next site)
which in turn is from here...
http://www.fao.org/fi/default.asp
which all started from here...
http://www.fao.org/
There is a real lack of what you are looking for. Possibly you could go down to a harbor or a boat repair place and look at actual installations and get more information. Sam
Old 02-03-2006, 04:38 AM
Rep: 10 Posts: 4
Thank you, sam & zerogara
I have been looking for much information but most of them are outdated. During my proposal presentation, my topic was highlighted as not a good one and the argument was that it was better to use gasoline engines since the advantage of a diesel is just fuel economy . Well, I proceeded despite warnings and i have few research papers on this and being a female, it seems slightly harder and got much harder since I can't get the most optimized route. The sites you introduced was indeed very helpful but i know i still need more. I can take off from here and I will ask you both if with any doubts Thank you very, very much. Thank you and lastly, what do you think ? Can this project be successful? Right now, I am concentrating on just one plus point , fuel economy.
Old 02-03-2006, 05:09 AM
Sander Rave's Avatar
Sander Rave Sander Rave is offline
Rep: 59 Posts: 201
How about low RPM torque and the better abillity to work on static revs?
...and what's wrong about fuel economy, it has my interrest!
Sander Rave
SkottKarra industrieel ontwerpers
skottkarra.com
Old 02-03-2006, 04:34 PM
I believe they run a LOT longer between overhauls. One of the biggest advantages is safety as the explosion and fire hazard is a LOT lower.
Old 02-04-2006, 11:03 AM
Rep: 59 Posts: 201
Exactly SamSam
Less explosion hazzard, when collecting gas in tank, bilge or any other place when not vented well.
Diesel engine is more expensive to buy if you look at the same power production.
Diesels weight more at same power.
Diesel needs a heavier battery to start
Diesel engines last longer, less service
They are more efficient on less then calculated power
They smell more
Sander Rave
skottkarra.com
Old 02-04-2006, 11:59 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
Look at actual boats over the years- diesel has come to thoroughly dominate most boat classes. Speedboats are still usually gas; anything with outboards is usually gas; some cabin cruisers that will never see the open sea are gas, as are some sailboats that don't use the motor much. Most serious working and cruising powerboats run diesel- it's more efficient, more reliable, and safer. The extra weight is often not a huge concern.
At 15 hp, you are usually in small gas engine territory. There are not many diesels this size; most 15hp motors are 1 or 2 cylinders and a one-cylinder diesel is not a nice machine to live with. But there are many designed for sailboats or stationary applications that are suitable. Unless you are required to design all-new equipment, I suggest looking up Yanmar, Deere, etc and seeing what they make that might be suitable. All the parts you need, except for possibly some mounting brackets, should be readily available.
Old 02-06-2006, 02:21 AM
Rep: 10 Posts: 4
Thank you
Thank you everyone. Most appreciated. I was asked to choose between an outboard or an inboard. i have found for dealkers for inboards and four dealers for outboards but while i was doing this, i found another engine installation method where the inboard is made into an outboard using motor mounting option with its propeller shaft fron the transom into the water. What do you know about this?
Old 02-06-2006, 07:44 AM
marshmat's Avatar
Simple answer: If the boat planes, gas outboard. If it doesn't, diesel or gas inboard. At least, that's the case with virtually all production boats using 15 hp.
Converting a diesel inboard into an outboard as you describe is not usually done, if I read you correctly.
Old 12-15-2011, 12:24 PM
CrescentEngine CrescentEngine is offline
Dear Arvi,
Which university are you at?
Diesel engines are generally used in large configurations, like trucks, ships, power houses, etc. There is some research to make a smaller diesel, but it is generally academic. only Fiat came up with a diesel in a very small car.
However, in the high-torque low rpm range, one can find the agricultural engines, nicknamed peter engines. They are noisy and dirty. You can hear them from the farms as you drive through the countryside!
If your project is a transmission system, use any petrol 2 stroke engine and any boat and get on with your work.
If your project is to design a diesel engine, then forget about the boat, and get back to me.
Old 12-15-2011, 02:19 PM
Mariner
Rep: 777 Posts: 1,543
CrescentE,
Please note the date on the post you've responded to: February 2006.
That's ~6 years ago now...
-Tom
DIESEL TRUCK engine Marinization FAST FRED DIY Marinizing 31 07-07-2006 02:26 PM
marinised diesel engine problem 2woods DIY Marinizing 9 11-10-2005 05:38 PM
Diesel Engine for sale wriand955 Marketplace 2 09-18-2005 12:07 PM
diesel engine ferryman mietchan Diesel Engines 1 06-15-2005 10:18 AM
Diesel Engine Efficiency winap Boat Design 7 07-11-2004 04:06 AM
