| homemade electric outboard anyone ever build their own electric outboard / trolling motor from scratch? i cant find any info anywhere ???..... so i turn to the best thanks |
| I have been doing some drawings using a 18V cordless drill and a 90`drive. I would like to build a prototype but don't want to spend a lot on proof of design model. Maybe this winter? It might be what the canoe, kayak people are looking for? |
http://www.youtube.com/watch?v=2ul6h...e=channel_page http://www.youtube.com/watch?v=GJedBprmSkk The second one uses a 330g model aircraft motor. The first one has a Mars PMSM but is limited to about 280W by the little 12V batteries. The Mars motor can go up to 9kW with a suitable battery. There is quite a lot of discussion on this thread: Efficient electric boat Rick W |
I made one because I had a low rpm brushless DC motor lying around for several years. Made a housing from stainless steel and even a multi-blade prop. Once it was ready I used it behind an 8 ft RIB a couple of times, but the fun was in making it, not using it. |
| i know you said use a low rpm motor but what size/type brushless dc motor would be needed? what kind of power supply would be most efficient deep cycle marine battery, lithium not really sure of the options. how do you determine how long the motor will run before all power is lost? would an electric scooter motor and battery be a viable source for my power plant? and finally how do you determine what kind/size of propeller to use in relation to the motor? it will be on my canoe. i would like to have a motor on each side. i just want to make a neat efficient propulsion system for my canoe because my friends are useless when it comes to rowing. i dont want to take the easy way out and buy two trolling motors i like building stuff myself. in addition my dad owns a auto salvage yard so i have a lot of parts at my disposal. i dont really know what parts if any would help me in my quest to propel my canoe sorry if im annoying im just a kid with a lot of questions that my teachers cant answer or even point me in the right direction. haha thanks again you guys are awsome |
| Rick will most likely step in with some tech talk, but a lot of this is uncharted and you need to do so trial and error testing, and let us know the results. I think the scooter motor and battery would be a good starting place. The gear box is your next hurdle! Flex shaft is also an option. They make some large R/C boat props you might look at. Maybe a heat and air motor from a car?? Or go to Wal Mart and get a trolling motor prop. For testing, maybe a 90` drill adapter? |
| If you have a pet idea and an appropriate electric motor, "suck it and see" just for the fun of it... otherwise.... Why buy when there are soooo many commercial options? - If you have absolutely no information, why start here - do some homework (personal research first), then pose some questions....
__________________ Try to be helpful... The trouble with people is to realise and remember that there are at least two sides for every story... A woman's breasts, one is not enough, - two may be just right, - but dreaming of 3 is a pleasant fantasy... |
http://www.boatdesign.net/forums/att..._boat_9kph.wmv This thread has some some data: Electric Boat Data For prop design you can use JavaProp. A model plane prop will be about the best you can get - much better than typical boat prop for these light load applications. Rick W |
| Ahhh now this is a different story, and far more in Rick Willoughby's field, where I would consider him to be an expert, be guided by him.... He is after high efficiency but you could utilise some of the technology to your advantage, like the long flexible external drive shaft (put the electric motor forward in a splash-proof box) - - maybe use a cheaper propeller or make your own 2 blade similar to that used by model aircraft but rotate at 300 to 1000 rpm in the water, salvage a controller from a busted electric outboard or make one up and salvage battery packs from busted electric drills (if the drill is busted the battery pack could still be OK, and the charger... - charge a dozen or so at home and when half are flat, time to head home ![]() ![]() ![]()
| When messing with the packs from the drills, wear safety glasses and keep a fire extinguisher handy! They pack a lot of quick power. |
| This is what I meant in post #4. Found it in the shed today looking for something else. I made it at least 15 years ago, maybe 20. At the time it seemed OK, now I would have shaped it a bit differently. There also was a controller with a joy stick, but I'm afraid it went into the dumpster. |
| look here for two vintage electric trolling motors. http://vintageboatplans.com/trolling/ you may need to find an alternative to the generator for the motor. Chuck |
| I did a little "kids boat" with an electric scooter motor, inboard, direct drive through the skeg. motor was rated 250 watts, 2500 rpm on 24vdc. it did about 1/2 that on 12v. motor was about 4" diameter (10 cogs per rev = 5 windings?) and big on torque. shaft was 5/16 stainless rod and the stuffing tube was hard 3/8" brakeline tubing I'd grafted a vertical oiling tube to (gravity fed). clearance between the rod/tube was a happy .005 (about), it pretty well floated. it swung a young T-6 prop. long story short, those electric scooter motors are pretty impressive. |
| I built one using an old broken 8hp output, replaced the gas engine with a 2.5hp (at 12v) pump motor that I ran at 36v (7.5hp). For a little boat, you might just try a cordless drill as-is, attach a prop to the drill and hold it underwater, just might work fine in water. haven't tried it myself. |
| Electric Outboard Fabrication | rogerstrube | DIY Marinizing | 6 | 11-26-2008 09:51 PM |
| electric outboard for 28ft catboat. | gschuld | Hybrid | 9 | 11-12-2007 12:55 AM |
| Electric Outboard Design | LSU SolarSplash | Outboards | 4 | 11-18-2006 09:25 AM |
| Recommendation for an electric outboard? | Mohan Pakkurti | Sailboats | 3 | 01-27-2005 11:09 AM |
| homemade outboard prototype | Machnumber2 | Boat Design | 0 | 05-25-2004 02:50 AM |
