Old 05-12-2011, 08:09 PM
nimblemotors nimblemotors is offline
Rep: 10 Posts: 92
Originally Posted by nimblemotors View Post
I built one using an old broken 8hp output, replaced the gas engine with a 2.5hp (at 12v) pump motor that I ran at 36v (7.5hp).
For a little boat, you might just try a cordless drill as-is, attach a prop to the drill and hold it underwater, just might work fine in water. haven't tried it myself.
Also wanted to add that many power tools will also operate just fine on DC, rather than AC power. So for example, you can take a beefy angle grinder and run it on 24v battery power, which would probably spin it at an RPM more useful for a prop than 120v.
Old 08-17-2011, 12:01 PM
Jeremy Clarkson Jeremy Clarkson is offline
Rep: 19 Posts: 25
Originally Posted by masalai View Post
If you have a pet idea and an appropriate electric motor, "suck it and see" just for the fun of it... otherwise.... Why buy when there are soooo many commercial options? - If you have absolutely no information, why start here - do some homework (personal research first), then pose some questions....
yeah arctic monkeys suck it and see good lp
Electric Outboard Fabrication rogerstrube DIY Marinizing 6 11-26-2008 08:51 PM
electric outboard for 28ft catboat. gschuld Hybrid 9 11-11-2007 11:55 PM
Electric Outboard Design LSU SolarSplash Outboards 4 11-18-2006 08:25 AM
Recommendation for an electric outboard? Mohan Pakkurti Sailboats 3 01-27-2005 10:09 AM
homemade outboard prototype Machnumber2 Boat Design 0 05-25-2004 01:50 AM
