Old 12-13-2007, 02:01 PM
adamanderr adamanderr is offline
Rep: 10 Posts: 18
gas block diesel head?
Where should i look for info or possibility of converting a gas block to run on diesel? is it as simple as bolting on compatible diesel heads, since fueling and valve etc are in head? what about having a head machined?
thanks
Old 12-14-2007, 12:40 AM
Kay9 Kay9 is offline
1600T Master
Rep: 235 Posts: 555
Pertty sure this wont work. I would think the air ports would be all wrong for a compression engine. I would also think that the wall thickness of a gas engine would not be big enough (read strong enough) to withstand the forces generated in the combustion chamber of a diesel engine. Also what would you do with the holes for the distributor and timming chain? I think you are wasting your time. Find an old diesel and rebuild it. If you cant find one let me know and I can direct you to several.
Old 12-14-2007, 02:00 PM
old750 old750 is offline
Rep: 16 Posts: 13
Just my 2 cents...
It can be done! But it wont last you very long.
GM did it back it the 80s with a v8 - i think the 350. It was a big flop. They converted to diesel. Biggest problem was the block not being stout enough, walls were too thin.
I'm thinking if the worlds largest auto company can't do it right, I won't even try it at home.
gas block with diesel heads adamanderr Diesel Engines 8 12-19-2007 01:48 AM
Water in engine - how likely is head or block crack? jhahn Gas Engines 9 09-03-2007 12:01 PM
planing gas to displacement diesel conversion jeemboNC Diesel Engines 14 01-20-2007 06:11 AM
Worldwide Gas vs Diesel pricing? FAST FRED Powerboats 22 11-26-2006 10:30 AM
Gas vs. Diesel torque comparison Chuck Bates Propulsion 12 09-04-2005 10:25 PM
