| Fuel Pump/Merc 302 Ford I was wondering if theres any reason why I can't put a regular auto fuel pump on a boat with a Mercruiser 302 Ford engine. The only thing I can see different is that theres a sediment bowl attached to the pump. Is this bowl absolutely neccesary or can I discontinue it. It will still run through the water seperator before the pump. The reason I ask this is because a regular Ford ford fuel pump is $20 and Mercury wants $98 for one. Put a starter solenoid in it today that I bought from NAPA for $7 and afterwards I looked up one from Mercury and it was $38 for the same thing. Crooks I tell yuh!!! |
| Im not all that familiar with marine engines, but I am very familiar with auto engines, especially small-block ford and chevy. One strange thing I've learned while my friend and I were restoring his 2 65 mustangs and 66, its that an autozone replacement fuel pump for a 65 mustang has a sediment bowl, while one for a 66 doesnt. These are both for a 289, which is the same block as a 302. So if you're needing the sediment bowl, get a fuel pump for a 65 mustang w/289 ![]() |
| Be very careful - I don't have any specific knowledge about your fuel pump (I'm not a mechanic), but the concern I would have would involve what happens if or when the fuel pump might fail. If the pump fails, will an automotive pump flood your bilge with explosive gasoline and vapor through a vent hole or similar? Likewise, automotive alternators, distributors, and starters can ignite any gasoline vapor in your bilge, while the marineized versions are "ignition protected" with the contacts sealed so they won't spark and ignite fuel vapor. |
| It is VERY DANGEROUS to put automotive fuel or electrical systems in boats. The marine fuel pump, which is still available, has a reservoir for fuel if the primary diafragm fails. Marine pumps have double diafragms, automotive pumps have one and spill fuel through a hole if it fails. The starter solenoid you put is vented and not sealed like a marine type. They are not crooks, but sell specialized equipment that is more expensive to manufacture. Also, your installation is illegal. You are in violation of Federal and State laws. It will also void any warranties an boat insurance you may have. In case of fire or explosion, you would also be liable. I have investigated many marine accidents and seen lots of boats burned or exploded because of automotive equipment installed in them. I encourage you very strongly to correct the installation with proper equipment.
__________________ Gonzo |
| http://www.uscgboating.org/regulatio...-FUEL/-F33.gif may help or confuse us all.but it is important to us all.
__________________ tomkane |
This is a link to the diaphram type fuel pumps. http://www.uscgboating.org/regulatio...L/FUEL-F11.gif |
| The stripper or overflow tube routes gas to the carburator where it is burned instead of spilled into the bilges.
| http://www.uscgboating.org/regulatio...L/FUE?-F33.gif The print-out I have shows a picture of a remote fitted fuel pump.There are regulation supplied regarding the fitting,and test for the type of fuel pumps used.
| Monohull verses Multihull powersailers / motorsailers | brian eiland | Motorsailers | 257 | 12-14-2011 12:10 AM |
| Cooling problem Ford 302 | san | Propulsion | 38 | 05-30-2011 12:44 AM |
| Luhrs T-29 (1995) diesel inboard converted to outboard | Iya | Boat Design | 13 | 03-07-2007 07:48 PM |
| Diesel hp rating not always what's advertised! | Chuck Bates | Diesel Engines | 34 | 04-18-2006 12:54 PM |
| Problematical Mercruiser Ford 302 (888) | JohnF | Propulsion | 14 | 12-15-2004 06:25 PM |
