Old 11-11-2011, 08:30 AM
SURRYEQUIP SURRYEQUIP is offline
Rep: 10 Posts: 5
Ford Tractor Diesel
I want to use a 401 Ford tractor diesel in a boat. The rear bolt pattern is the same as 2000 ford tractor thru 8000 ford tractor- Can i get some suggestions as to how to hook up a trans to this- I can imagine accurately fabricating an adapter could be tricky. Thanks
Old 11-12-2011, 07:08 AM
whitepointer23 whitepointer23 is offline
Rep: 247 Posts: 655
look up bowman or lehman, you can purchase everything you need to marinise a ford diesel. sabre was another company and lees.
brendan .
Old 11-12-2011, 09:13 AM
Rep: 1493 Posts: 7,447
If you use a Velvet Drive transmission, there should be a SAE bellhousing for it.
Old 11-16-2011, 05:52 AM
Rep: 756 Posts: 3,328
I would contact Twin Disc for a transmission is this is a blue water boat.
If you look in www.boats-and-harbors.com/ , a rebuilt can be had for far less cost than "new".
FF
Old 11-16-2011, 03:05 PM
Rep: 1729 Posts: 2,462
If you cannot find a housing to suit your gearbox then making an adapter plate/bellhousing replacement is not that hard these days with NC cut steel plate.
Mike Johns.
Realistic sell price? 6cylinder 125hp Ford Lehman diesel SpiritWolf15x Diesel Engines 7 02-05-2012 01:42 PM
Rebuilding and marinizing tractor trailer charlesakeem DIY Marinizing 3 04-21-2008 10:06 AM
OMC to Ford 5.0 AndrewH Inboards 2 02-20-2008 08:27 PM
Diesel/Electric vs. Diesel/Hydraulic? GumbyTheBorg Hybrid 7 06-27-2006 09:11 AM
Marinising New Holland Tractor Diesel Bradley Powerboats 8 03-05-2005 04:55 AM
