Old 12-24-2009, 10:33 AM
hdflame hdflame is offline
Rep: 10 Posts: 4
Foot Controlled Trolling Motor Plans/Parts???
I am wanting to build a Gator boat and use a trolling motor on the back for power. I have seen them mounted with a pulley on top of the shaft, with cables going up to foot controls so it can be guided hands free while fishing.
Has anyone done this or know of sites/plans/instructions/parts list that I can get ideas from?
Thanks,
Bobby
Old 12-24-2009, 11:42 AM
mark775
Like this?
Foot Controlled Trolling Motor Plans/Parts???-s7_020380_imageset_01.jpg
Try here.
Sure you can start taking sewing machines apart but you are going to have more money into a less suitable product than if you just Google it and start shopping.
Old 12-24-2009, 05:13 PM
Rep: 10 Posts: 4
Originally Posted by mark775 View Post
Like this?
Attachment 38638
Try here.
Attachment 38639
No, what I'm talking about is sitting low on the bottom of the boat (Chair mounted to bottom) with your legs extended down port and starboard side of livewell. A pedal on right side and a pedal on left side....press on right pedal to go right, press left pedal to go left. There would be a cable attached to each pedal running back to a pulley on top of the trolling motor shaft. You also mount a set of toggles or rocker switches for on/off, forward/reverse.
I've see one before made from a cheap straight shaft motor with the top handle/controls removed and the pulley attached to the top of the shaft. I have one like you posted the picture of, but it won't work for the application I want and would be too expensive to chop up for parts. I use it on a larger boat.
I thought if someone knew of a supplier of parts like foot pedals and pulleys, I wouldn't have to make or source them myself....didn't want to re-invent the wheel if someone had already done it.
Old 12-25-2009, 01:57 AM
liki liki is offline
Rep: 104 Posts: 158
There are trolling motors with an electric remote control which can be mounted on your rod.
Old 12-25-2009, 07:06 AM
Charles N Charles N is offline
Rep: 10 Posts: 2
A few kayaks use that type of setup if you want to google kayak and electric motor I'm sure you'll get some ideas, alternatively the protroll might be an out of the box solution.
www.procontroll.com/index.html
Old 12-25-2009, 09:42 AM
Rep: 10 Posts: 4
Maybe when I hit the lotto!
$399 for the remote and over $1,000 for the trolling motor from Bass Pro. I think I'll come up with something different!
http://www.basspro.com/webapp/wcs/st...001000_225-1-0
Old 12-25-2009, 09:45 AM
Rep: 10 Posts: 4
That looks like a possible solution. Not out yet, but supposed to be about $150 when it comes out in Jan 2010.
trolling motor on a kayak joco Outboards 18 12-12-2009 09:19 PM
Johnson Trolling motor, what can you tell me about it. thudpucker Outboards 5 07-18-2009 10:00 AM
Trolling Motor Boat jagermeister24 Boatbuilding 0 06-19-2008 11:30 PM
folding, electric powered, foot controlled boat with augers instead of props john zimmerlee Boat Design 3 06-11-2008 11:38 PM
Trolling Motor Harness dereksireci Electrical Systems 0 11-16-2007 01:59 PM
