Old 07-11-2004, 03:30 AM
Engine gear box
Hi there, just wondering if anyone can help me. I am looking at putting a 350 chevy engine in a ski boat. It has been maranised but was run in a jet unit so I am getting it back to the flywheel. I want a direct drive through to the prop. Would I need some sort of gear box on the motor before the shaft and if so would sort of ratio would be good. If not what else could I do.
Thanx
Old 07-11-2004, 04:30 PM
Black Swan Black Swan is offline
Rep: 10 Posts: 28
Most "tounament" style ski boats run direct drive from flywheel through a forward/neutral/reverse transmission. The most common of these would probably be the Borg Warner 72C, readily available. Gear reduction is not a necessity, just prop the unit appropriately for your boat. Lots of information available, just visit a tourney boat dealer. Don't forget to pay attention to the skegs, struts, stuffing boxes, rudder/steering systems and control and cable systems.
Old 07-11-2004, 05:09 PM
Corpus Skipper's Avatar
Corpus Skipper Corpus Skipper is offline
Hopeless Boataholic
Rep: 173 Posts: 604
I'll second that. I've got two of them (1.91:1 reduction) that are older than dirt and still going strong (knocking on wood)
Craig Cavanaugh
Silver King Custom Marine
No shoes, no shirt, no problem!
Old 07-11-2004, 05:43 PM
lots_of_knots lots_of_knots is offline
Rep: 10 Posts: 2
slow running and acceleration will be much smoother with some kind of reduction gearbox
Old 07-11-2004, 10:50 PM
Rep: 1397 Posts: 7,215
If you put a flywheel, it will need a new harmonic balancer to match.
Old 07-12-2004, 03:14 AM
Rep: 10 Posts: 28
Ski boats are rarely challenged with the need to run slow. Mostly you are looking for a good quick smooth acceleration to 30MPH and the ability to hold that speed while the skier flails around on the end of a rope. If the engine was properly "marinized" the proper flywheel and harmonic balacer should already be there. You may have to get a new "flex plate" which bolts to the flywheel and has the splined centre adaptor which then mates to the splined shaft of the transmission.
If you're propped right, you should achieve your target speed with the 350 running around 3200 to 3600 RPM. This puts the engine in a good torque range and is a good place for the kind of "fingertip" throttle control that's needed for tournament type skiing.
Old 07-12-2004, 11:39 AM
Hopeless Boataholic
Rep: 173 Posts: 604
These are readily available on the 'net. Just search for borg warner drive plate (assuming you go with a velvet drive) and you'll get a lot of returns.
Craig Cavanaugh
Old 07-14-2004, 09:14 AM
Rep: 10 Posts: 2
i thought all engines required a harmonic balancer to smooth out crank vibrations caused by the crank webs winding then springing back during every power stroke, at the least a new one should be fitted and checked regularly
Old 08-08-2004, 07:03 PM
Jets Jets is offline
Rep: 10 Posts: 15
I have an Olds V6 from an '85 cutlass (rear drive. The engine was balanced at the factory internally for a flex plate and no harmonic balancer (automatic). I have read elsewhere on the net that I cannot change to a real flywheel because of the method of balancing.
Old 08-09-2004, 12:28 AM
If the engine is internally balanced then they didn't use the flywheel to counterbalance the crank, pistons, etc. In that case you can change to another flywheel with a matching harmonic balancer.
Old 08-09-2004, 07:32 AM
Rep: 10 Posts: 15
Apparently not because they remove material on the crank to achieve balance with the flex plate and/or flywheel - harmonic in place. It is not a memorable motor, this Olds V-6. It is a 90 degree block with offset crank journals and un-ajustable valve train. It was cheap. I put in a cam to make about 150 hp and it is in a 13.5 ft 1961 Glasspar G3 hooked to a cog belt driving a surface piercing prop through the transom. I am still trying to get a good prop.
Old 10-23-2004, 07:34 PM
decay21450
love the g-3's. anybody ever repower with a merc sportjet or omc turbojet?
How to make snowmobile engine work in a small 11 ft. runabout? rvBilly Propulsion 8 09-02-2005 10:49 PM
Propeller sizing and engine loading E4ODnut Props 3 12-29-2004 05:50 PM
Engine Torque Curves Pat B Propulsion 22 10-06-2004 05:36 PM
Diesel Engine Efficiency winap Boat Design 7 07-11-2004 04:06 AM
