| They are probably all right to some extent. A lot depends on the company that marinizes the engine as well. As far as parts: they are intercangeable to the extent that the holes line up. Some parts will be identical and some may be modified. My block in my marine power chevy for example appears to have some sort of coating in the water jackets. It then has four bolt mains like a truck or HP motor. The pistons are forged and has HP rods and forged crank. The heads were junk. It had sodium filled truck valves that disintegrated. It now has modern Dart iron eagle heads. The carb is different as is the alternator and starter. And obviously the cam is different. So other than those things it is exactly the same as a car engine ![]() |
| Your 305 Marine Engine is closer to a Truck engine. The same or almost the same cam, different gasgets and soft plugs as well as intake manifold, carb, starter and alternator. |
| " From the media I thought global warming was a big issue but if the air is cleaner then global warming is going away" Global warming is Hopefully NOT going away. WE are between ice ages , the warming is NORMAL , although we havent yet reaches the usual peak temperatures between Ice Ages. When we do the globe will again (after a few thousand years) be covered with 300ft thick ICE as far south as NYC. A far more daunting hassle than "warming". FAST FRED |
This guy does engine swaps for a living, and he operates out of California. The page I linked to goes over the process of having an engine swap legally certified in California.
__________________ Stonebreaker Ph.D in Redneck Engineering - Piling it higher and Deeper. |
| Global warming - bring it on. All you people out there with sail power are not helping at all. 4 degrees C this morning all because of the people using sails instead of proper engines. |
| Dangerous designs? | usa2 | Sailboats | 186 | 01-19-2006 07:24 AM |
| French/English | MikeJohns | Open Discussion: All Things Boats & Boating | 6 | 01-16-2006 04:08 PM |
| marinizing a snowmobile engine and drive setup? | rvBilly | DIY Marinizing | 2 | 09-07-2005 07:50 PM |
| Le Magazine De La Mer | intechno | Open Discussion: All Things Boats & Boating | 1 | 02-06-2005 02:18 PM |
| New Forum Proposal: DIY Marinizing Engines | gonzo | Forum Questions and Suggestions | 8 | 09-03-2004 10:06 PM |
