Old 02-24-2011, 10:03 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,252
Originally Posted by fishon91 View Post
CDK, i like this fitting. Do i need to add water filters further down the line or not? if so, what kind of filters?
I don't think so. The largest items to pass the slits are small leafs: the pump can handle that.
Old 02-24-2011, 10:07 AM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1693 Posts: 5,867
Small leaves and big leaves and some more stuff you dont know about.
A filter would be good and advisable. Like a proper boat.
Old 02-24-2011, 10:18 AM
fishon91's Avatar
fishon91 fishon91 is offline
Rep: 10 Posts: 43
gonzo, i meant JUST relocating the water inlet and bypassing the pump with electrical pump. no radiator.
i dont even know that the advantages would even be worth the work on this anymore.
the boat is a 1436 and a thin hull, no air propeller is goin on this rig.
Old 02-24-2011, 10:20 AM
fishon91's Avatar
Rep: 10 Posts: 43
sorry, didnt see these last two posts.
youre saying i wouldnt need to worry about sand or little bits of mud goin through the motor?
of course as long as i keep a good eye on everything, flush the motor after every run.. etc...
Old 02-24-2011, 10:34 AM
Frosty's Avatar
Fishon with all due respect no one has done this, everyone is guessing.
If you want to do stuff like this you need to be mechanically minded and able to work things out on your own.
Sooory but that how it is,-- no one has done it.
Old 02-24-2011, 11:19 AM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
Also, you mentioned, cost is a big factor. When you start pioneering things not commonly done, you run into added expenses, down time. Two steps forward, one step back kinda stuff. Keep it simple, and do what's proven. You're in a tough spot my friend. Good luck.
-Tom
Old 02-24-2011, 11:52 AM
fishon91's Avatar
Rep: 10 Posts: 43
HAHA im in a very tough spot. i prbably will and up not doin anythin like this. i built a longtail a couple years ago and ran into the added expenses, one step forward, two step back kinda thing. and thats why im in the position im in now. i jus need to keep my eyes out for a good longtail for a good price that i can afford.
thanks yall
Old 02-24-2011, 05:16 PM
Erich_870's Avatar
Erich_870 Erich_870 is offline
Rep: 15 Posts: 49
You really should contact that guy I mentioned. He's done it and can tell you all about it.
Erich
Old 02-24-2011, 08:11 PM
fishon91's Avatar
Rep: 10 Posts: 43
erich, i just tried to join the refuge forum and it wouldnt let me use a yahoo or hotmail email, those are the only two emails i have access to. is there another way?
  #25
Old 02-24-2011, 09:42 PM
Erich_870's Avatar
Rep: 15 Posts: 49
Arrrg, that's the most annoying thing about that forum. I had to use my work email for that exact reason.
I'll see if I can find the exact reference and send you the link.
Erich
  #26
Old 02-24-2011, 10:55 PM
Erich_870's Avatar
Rep: 15 Posts: 49
Here's the thread I was thinking of: http://www.refugeforums.com/refuge/s...ighlight=angle
Erich
  #27
Old 02-25-2011, 01:36 AM
pistnbroke's Avatar
I try
Rep: 387 Posts: 1,269
briggs and stratton will push you about 10 mph...b and s dont make them any more so you need look at second hand ...
Closed Cooling, or Not Blue Heron Sterndrives 19 03-05-2010 07:10 AM
Closed Cooling System (Half) Lawrencemd DIY Marinizing 5 02-10-2010 03:14 AM
Changing to a closed cooling system..?? Jbird Sterndrives 11 12-29-2007 07:03 AM
chrysler 440 closed system cooling help mlcorry Propulsion 7 08-17-2006 10:40 PM
Zebra Mussels: Raw or closed cooling? Richard Petersen DIY Marinizing 9 01-15-2005 07:22 PM
