Old 02-26-2006, 03:16 PM
erinj erinj is offline
Rep: 10 Posts: 3
auto engine replacement for blown 455?
I've got a boat with a blown 455 olds. I'm wondering what my least expensive option would be for replacing the engine. Would an automotive engine bolt up? Anyone have any ideas or know how I can find out which engines will be compatible with the existing adapter and berkeley jet drive? Thanks
Old 02-26-2006, 04:56 PM
Thunderhead19 Thunderhead19 is offline
Rep: 21 Posts: 504
The block (despite what others may say) is identical to a stock auto block. Your job would be to strip down the boat motor including the cam and install the old components on a new short block. Just out of curiosity, by "blown" you mean what? What happened? threw a rod? seized? destroyed the #1 main?
JDF
'"Forward, the Light Brigade!"'
-Alfred Lord Tennyson
Old 02-26-2006, 06:05 PM
Rep: 10 Posts: 3
Thunderhead,
What automotive engine could I use as a replacement? Does it depend on the existing specific adapter and jet drive?
It threw two rods and engine filled with water.
Thanks, erinj
Old 03-02-2006, 12:24 AM
Rep: 21 Posts: 504
I think you may be able to go with any GM big block V-8, but I'm not 100% sure. Couldn't you find a 455 replacement? Most reduction gears and or drive units will fit a selection of different motors. I think you may find that one adaptor fits all GM big blocks, one adaptor fits all Ford small blocks etc...Can't say 100% for sure though.
JDF
Old 03-07-2006, 06:23 AM
Rep: 700 Posts: 3,208
BOP, Buick Olds Pontiac , will usually swop and the belhousings will fit.Chevvy is different
Just get another Olds 455 and swop as recomended.
When GM built motorhomes in the 60 & 70'd the Olds 455 was THEIR choice for the most robust engine in the lineup .
If GM thought it was the best they had , and you have all the boat conversion goodies , a rebuilt Olds seems like a no brainer.
If you want a cheap huge engine the 500cid Caddys from the 70 are as big as you can get and are cheap .
FAST FRED
Old 03-18-2006, 04:54 PM
Rep: 10 Posts: 3
Thanks, Fred
Fred, I didn't check in for awhile and just saw your reply. Thank you for the iformation. I appreciate that you and the others have offered to share you knowledge on the subject. I'm sure I'll be posting more questions about this subject. Thanks again, erinj
1974 455 Oldsmobile jetboat engine Tdela55 Powerboats 49 12-09-2011 05:43 PM
455 Olds block engine jetboatjill Marketplace 1 07-03-2011 08:29 AM
Auto engine marinization DIY Marinizing 231 07-01-2010 08:34 PM
Engine Replacement WinFlex Propulsion 14 10-24-2004 04:58 AM
Engine Replacement help Kyle@ DIY Marinizing 3 03-26-2004 11:44 PM
