  #226
Old 03-01-2009, 03:31 AM
rexxer rexxer is offline
Rep: 10 Posts: 5
Thank you CDK. That was the first thing that has made sense to me since buying this boat
  #227
Old 03-01-2009, 06:39 PM
Rep: 1397 Posts: 7,216
The 3.0 Chevy was very succesful in cars as tens of thousands of taxis can prove. The upside of it is that since they made millions of them, parts are available and relatively cheap. By the time you marinize the other engine it will cost you more in parts and time than rebuilding what you got. Also, it is such a common engine that the machine shop will be familiar with it
  #228
Old 03-01-2009, 07:00 PM
rasorinc rasorinc is offline
Rep: 682 Posts: 1,130
Wasn't this posted originally under another heading? Pleas do not double post.
  #229
Old 07-01-2010, 06:23 AM
Machineman Machineman is offline
Rep: 10 Posts: 5
Whatever!
Originally Posted by gonzo View Post
I don't know how it is where you live. Here, marine engines are fuel injected and have the latest technology in electronics. If you were to use an automotive fuel injected, computer controled engine, the changes would be beyond your capabilities. For example, how do you reprogram the computer to account for a marine engine not having an oxigen sensor. It cost more to marinize an automotive engine than starting with a marine one.
There are many ways around the problems that are constantly claimed to be too difficult to solve. Basically,
1. Change the obvious, fuel pump and starter etc for safety.
2. Do not use raw water, just run a heat exchanger and do not change the engine at all. No gaskets or anodes or ANY of that rubbish. Leave the engine alone in it's own cooling fluid. It will run at normal temps and no "shock from raw water temps" it's all rubbish and fear mongering fuel "boiling" blah blah blah.
3. Biggest issue is a set of custom exhaust manifolds, that can use an o2 sensor, get em made or make them yourself but save an absolute BOMB of money to power your boat compared to ridiculous marine dealers. They rely on people complying to their way.
4. Overpower your boat, no need to run at 5000rpm+ to plane, if so you have the wrong gearing/prop. You will read pages of crap here about why it won't work, BUT, if done well, it works better than any marine dealer wants you to know.
So, be safe, cool your driveline well and set up good monitoring for heat. Ventilate engine bay and fuel storage bay (all things that "marinized" set up's require anyway.)
I personally think that threads like this fail to understand the point, people would not ask for advice if they had enough $$$ to buy great new marine gear. I have had way more satisfaction in boating by using modern efi engines to power home built hulls with surprising reliability, way more fun than when I got "violated" by a sea Ray salesman when purchasing a 270 sun deck for $80aud.... I have felt like a fool ever since.
Be safe and marinize anything you want, more fun and cheaper than your local rip off marine merchant.
  #230
Old 07-01-2010, 07:13 AM
Rep: 10 Posts: 5
Give Us A Break Please
The marine version of the engine has an electric system that is explosion proof. The fuel injection is self contained and legal for marine use. The cylinder temperatures of an engine in marine use are much higher than in a car, even a race car. It is the equivalent of running a vehicle with a full load at WOT uphill for hours on end. Boats don't reach cruising speed and then require less power to maintain it. A larger gap is necessary for extra thermal expansion. It is not bogus. Also, Mercruiser engines have Vortec cast iron heads. Aluminum heads wouldn't last long in salt water. I sell new 5.7 engines for $5495.00 complete. The link to the engines you sell is advertising a base engine. The comparison is really bogus.
Gonzo, have you read the above info, it's a fact, they are the same thing with a sparkless electrical system which is in itself debatable in need. When is the last time a boat exploded and was not leaking LPG, engine fuel explosion? When?
Save the self promotion for work.
  #231
Old 07-01-2010, 10:35 AM
CDK's Avatar
CDK CDK is offline
experimental engineer
Rep: 1316 Posts: 2,145
This thread is sleeping for a few months already, but I like your attitude.
Solving the O2 issue is even easier: leave the sensor terminal on the MMU open and it will immediately substitute a fixed value for the sensor output. It also switches the malfunction warning light on, which you can ignore.
  #232
Old 07-01-2010, 08:34 PM
Rep: 10 Posts: 5
Nice O2 solution.
Thanks, I have always tried to alter the function of the engines as little as possible but may have wasted a fair slab of time in unnecessary inclusions.
This will make my next set of manifolds even easier and I'll disconnect the warning light, or like you said, just ignore it.
Thanks for the tip.
DIESEL TRUCK engine Marinization FAST FRED DIY Marinizing 31 07-07-2006 02:26 PM
How to make snowmobile engine work in a small 11 ft. runabout? rvBilly Propulsion 8 09-02-2005 10:49 PM
Engine Torque Curves Pat B Propulsion 22 10-06-2004 05:36 PM
Diesel Engine Efficiency winap Boat Design 7 07-11-2004 04:06 AM
