| Air cooled Diesel repower Hello, Just beginning to start a new project, repowering a 22 foot Galion Yacht. The original inboard was a two stroke petrol (vire) engine which is beyond saving. Due to width and weight constraints it seems near impossible to fit any of the marine diesel engines currently in production. I do however have a Hurth hbw 10 gearbox and a yanmar L70 air cooled diesel engine. My plan thus far is to couple the engine and gearbox together (they are the correct rotation) with a bell housing and use a standard 4 inch coupling with elastomeric insert to join the shafts. Still in the design stage at the moment, any ideas on the coupling the engine to the gearbox would be appreciated, I know the correct way is with a damper device bolted to the engines flywheel that the gearbox splines connect to, however the flywheel is on the wrong end of the engine for this to work. I realise that I have significant work to do to make this system work including ducted cooling and sorting an exhaust. At present I plan to run an alternator and water pump from the engines front pulley and use a jacketed exhaust loop with water injection. |
| And your question is? |
| If anyone has any similar experience, particularly in coupling the engine to the gearbox?. and if the idea is sound or have I missed some major stumbling block?. my main concern is if coupling the engine to gearbox directly in this way will damage the gearbox due to the loading/unloading of the shaft during the firing pulse? |
| BMW uses these in their drive shafts, might be some way to make a flange for your needs? |
Some sturdy engines allow you to take considerable power from the shaft also, but it should never be the only engine load. The shaft may break from metal fatigue after only a few service hours and ruin your project. |
| the design of the engine is similar to a lawnmower, with a shroud covering the flywheel (which has blades to act as a fan to force air through the engine.) the only output from the engine is the shaft. there is a pullstart mounted on the flywheel side of the engine. I have (hopefully) uploaded a photo of a slightly larger engine along with the gearbox that I intend to use. the engine i will be using is near identical but is 7hp instead of 10. I will do some more research on this area. many thanks for the advice. |
| Hatz Diesel! if you can afford it! |
| MASE patents and semi air cooled genset. | fcfc | Electrical Systems | 1 | 07-29-2007 09:35 PM |
| Ducati IS-11 air cooled diesel | martinwill | Diesel Engines | 0 | 03-11-2007 06:15 AM |
| Air Cooled Inboard? | feetup | DIY Marinizing | 10 | 03-08-2007 11:20 AM |
| Air Cooled Gas Engines???? | CaptPPan | Powerboats | 19 | 08-05-2004 02:37 PM |
| Petter Air Cooled JP4 - Should I? | KeenEddy | Powerboats | 0 | 06-02-2004 02:13 PM |
