Old 07-12-2004, 07:24 PM
FIBER FIBER is offline
Rep: 10 Posts: 2
5.7l Engine
The engine on my 1988 Searay Sorrento S23 has developped what seems to be a crack in the block. Water is leaking into the oil. It is a 5.7L Chevy. I need to know if a 5.7L automotive engine will work ( mounts, exhaust, etc...) and what is required ? Can I use the automotive engine and just have to transfer the marine components? Any help is appreciated.
Old 07-12-2004, 07:30 PM
Corpus Skipper's Avatar
Corpus Skipper Corpus Skipper is offline
Hopeless Boataholic
Rep: 173 Posts: 604
Check the head gaskets first, that's the most likely source. Otherwise, check out this thread http://boatdesign.net/forums/showthread.php?t=650
Craig Cavanaugh
Silver King Custom Marine
No shoes, no shirt, no problem!
Old 07-14-2004, 10:27 PM
Rep: 10 Posts: 2
Other than disassembling the engine, what is the best way to pinpoint if the problem of water getting into the oil is from the head gasket or a crack in the block?
Old 07-15-2004, 02:15 PM
atroader atroader is offline
Yes, you can use a non-marine long block. The only thing I would be weary of is using a street cam versus the marine cam you currently have. Also, dont use a high volume oil pump if your current oil pan is 5 qts or less.
Old 07-15-2004, 08:19 PM
Hopeless Boataholic
Rep: 173 Posts: 604
A compression check will usually verify a bad head gasket.
Craig Cavanaugh
Old 07-16-2004, 03:07 PM
War Whoop War Whoop is offline
Rep: 84 Posts: 661
Let’s see head gaskets, brass freeze plugs ,marine cam and , marine rated valves should do the conversion.
Slippery when wet.
www.cheetahcat.com
Old 07-17-2004, 01:00 AM
dannobee dannobee is offline
Are you sure it's not a riser or exhaust manifold leaking? These are far more common than cracked blocks and blown head gaskets.
Old 07-17-2004, 08:56 PM
Rep: 2891 Posts: 8,795
I'm inclined to agree with dannobee on this, as the small block Chevy engine is known for cracks from the head bolt holes to a water jacket, spark plug to exhaust valve seat on cly's 3-5 or 4-6, risers and manifolds are a common source for leaks. The wrong length bolt in the waterpump boss on the front of the motor and a bunch of other places water can be getting into the pan.
Do a leak down test on it and insure this is for sure, then a compression check (maybe you'll get lucky) Odds are you'll pull the heads for a look see (not that bad of a job really) the average back yard wrench can do this in an afternoon (take lots of pictures before and during the process, trust me)
Old 09-10-2004, 11:23 PM
Rep: 1397 Posts: 7,215
Head bolts can also leak water into the oil. They should be sealed with gasket or thread sealant. Automotive engines have several differences. For example the bearings, oil pump, pistons, valves, camshaft, gasket material, freeze plugs, all the electrics, fuel pump and more.
OMC Johnson 50 hp 2001 engine problem Guest Powerboats 8 11-05-2008 09:57 PM
Engine Torque Curves Pat B Propulsion 22 10-06-2004 05:36 PM
Diesel Engine Efficiency winap Boat Design 7 07-11-2004 04:06 AM
Portager's Light Weight Engine Portager Boat Design 0 07-22-2003 02:57 AM
