| 4.3L Vortec mercruiser cracked block - swap with automotive engine block? Hello, I've been reading through many many threads, and it seems like I do have hope, afterall... I have(had) a mercruiser 4.3L Vortec engine on my boat, and it was not winterized properly and received a cracked block in return. some said, "get a new 4.3L Vortec engine out of an old blazer or s-10, throw the old marine parts on the new engine and change out the freeze plugs to brass". Then I got the, "You can't marinize an auto engine, it just doesn't work that way". So, My question is, since I have a non-working marine engine sitting right next to me and now I have a chance to pick up a working 4.3L Vortec engine out of a 96 blazer, can't I just mix-and-match? what else do i need to change out to make this a working marine engine? Thanks for any help! -sorry, should have made a better title for this, it is not about a cracked block, but about marinizing an engine.. Last edited by mmanning63 : 06-19-2010 at 09:55 AM. Reason: bad title |
| Shouldn't be a problem changing the Truck Engine to marine. Safety is the primary concern: You NEED TO USE THE MARINE: 1. Carburator or injection system 2. Starter 3. Alternator 4. Distributor Anything that exposes gas fumes or Electrical spark If the Truck is a standard shift, the Flywheel should be OK, otherwise change to the marine |
| Since you have the defect engine with all peripherals, swapping the engine blocks doesn't present any special problems as long as no bolts are too rusty to remove them without damage. Use new gaskets for the exhaust manifold, fuel pump and thermostat housing and put the Mercruiser water pump on because it has a different impeller.
| You might want to check with a Mercury marine parts dealer the cam shaft might have a different profile.
__________________ Yours Aye! Rick M/V She:Kon Blog ~^~^~^^~^~^~^~^~^~^~^~~^~^~~^~^~^^~~^~^ "It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up! |
| The Merc dealer probably is inclined to say the cams are different because that has been suggested lots of times. A fact is that there are "performance cams" offered by 3rd parties, but I doubt Mercruiser installed these in a standard engine. mmanning63 has both the marine and automotive engine: I hope he lifts the camshaft covers from both, looks at the shafts and posts here whether or not they are different. I am waiting with bated breath!
| It will be difficult to see a difference between the Truck and Marine cams. I was told, in most instances, they are the same cams. Unless performance is noticeably different, I would " Leave well enough alone " It's a mistake to install a " High Performance" Auto Cam. Boats need alot of torque, like a truck, especially at lower RPM's. |
Oh, they'll say that the marine *version* of an engine has "special" this or that, but try to nail 'em down on what exactly "special" means. Then ask 'em why the "special" bits can't be unbolted and swapped between the engines you're talking about. There's nothing magical and mysterious about any of it. They do want you to think there is though..... ![]() I guess for extra giggles, you could ask them how the "marinize" term came about in the first place. It seems as though at some point someone took an engine originally designed and built for something else.....and then "marinized" it. ![]() |
All too often, marinizing is treated as if it's mysterious....and it's really unnecessary and bordering on the ridiculous. You take an engine and bolt on the required bits needed to make it suitable for the application. If you had an engine in your boat that wasn't winterized and cracked or something similar, you obtain a replacement.....and transfer some parts. Unbolt/bolt. Repeat as necessary. Rocket science it ain't. |
| He already has the alternator, starter, carburettor and camshaft but I would not change the cam as it is already in a truck type application needing torque. Just swop it all over, you do not need stainless head gaskets and stainless water pumps (if it is stainless) because you are a fresh water cooling, but if you got the pump then you could swop. A good days work, nice simple job. In Uk in the 60's there was no such thing as a marine engine for sports boats, ALL boats had car engines in them. Car carbs, alternator (or dynamo) and I never ever saw one on fire ---ever. |
You may get away without using the "Marine" components. But that is because the system is intended to be safe in the event of a single point of failure. And 99% of the time there won't be any failure. Like a fuse in ones home. 99.9% of the time a copper penny would work even better. |
| Dont forget GM also sell the marine version of that engine so any GM dealer can tell you if the cam is the same in the marine engine versus any other spec engine. Merc only change cams in the performance engines, stock engines come with GM's marine cams http://www.gm.com/vehicles/innovatio...ne_engines.jsp
__________________ Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers..... |
| Distributors on boats have a spark arrestor too. It is only a pipe with an elbow. The fuel pump is different too. The camshaft will have a different profile but fits the other block. The exhaust valves are Stainless in a marine engine, I don't know what a Blazer has. The oil pump is a low pressure high volume. It is about twice the height, but the pressure spring is weaker. The harmonic balancer is a bit different too, but it will fit the other engine. The head and intake manifold doesn't have EGR or vacuum pickup. L67Supercharged: if you are selling automotive electrical items for boats, it is illegal and dangerous. There are some snide and slanderous remarks about marine mechanics in this thread. I am one and can tell you exactly what the difference is between the engines.
__________________ Gonzo |
| auto vs marine differences Not sure if this thread is still being followed, but i am going to post info some info about differences in a 1998 Vortec marine engine versus a 2006 Vortec automotive engine for all those wondering, because it is my understanding that actual bearing clearances are also TIGHTER on the automotive engine and this would make sense to me as the engine requires 5w20 oil(very thin) and the marine version requires 20W40(pretty thick) and if you use the thicker oil in the auto engine, i would imagine it to be similar to an oil starvation of the bearings and probably cause some excessive wear...not quite sure yet but i will be taking measurements and recording part number differences on everything...both are in very good condition, any thoughts or questions, suggestions...shoot me a line! Rob |
| Volvo Penta - cracked block??? | hka61 | Inboards | 5 | 12-03-2007 06:05 PM |
| Big block or Small block? | Verytricky | Inboards | 15 | 10-10-2007 12:04 PM |
| merc 4.3 rebuild - cracked block | 4.3rebuild | Sterndrives | 3 | 04-09-2007 08:31 AM |
| cracked block | shelbygone | Gas Engines | 3 | 10-11-2006 07:57 PM |
| what is the normal operating temp for 305 small block mercruiser chevy? | mattcat79 | Gas Engines | 2 | 08-22-2006 10:12 PM |
