Old 05-16-2010, 06:59 PM
muddin redneck's Avatar
muddin redneck muddin redneck is offline
DO IT IN THE MUD!!!
Rep: 26 Posts: 95
24 Hp Mudmotor Finally Finished
over the past several months i have been working on building a 24hp mudmotor using a honda engine. i got the idea to build it from all the posts on the weedeater conversions thread. today was the maiden voyage for it. it ran good but i have to install a cavatation plate for sure. seen a guy at the lake that also had one (factory job) so looking at his helped a lot. hope yall like what ive done. still a few kinks to work out but all in all today was a success. any questions or comments by all means let me know.
parts:
  • 24hp honda engine
  • 3/4" shaft 72" long
  • 1 7/16" x 3/4" u joint
  • 3/4" flange bearing (upper)
  • 3/4" tapered roller bearing and cup (lower)
  • 4- 3/4" oil seals (one in upper part of tube 3 in lower part of tube)
  • 2- 3/4"x1" brass bushing (spaced 20" from top of tube and 20" from bottom of tube)
  • tube is made from 1 1/4" x1/8" dom tube it is 56" long
  • upper and lower bearing and seal housing made from 2"x3/8" dom tube and machined to fit bearing cup ,seals and 1 1/4" dom tube
  • motor base plate is made from 5/16" plate
  • motor mount is made from angle iron and plate steel
  • tiller is 1" tubing
the bottom roller bearing is packed in grease and has a grease fitting and then the tube was filled with 80-140 gear oil
24 Hp Mudmotor Finally Finished-24hp-honda_2_1.jpg  24 Hp Mudmotor Finally Finished-lower-bearing-seal-housing_1_1.jpg  24 Hp Mudmotor Finally Finished-upper-seal-housing_1_1.jpg
24 Hp Mudmotor Finally Finished-upper-frame_1_1.jpg  24 Hp Mudmotor Finally Finished-lower-frame_1_1.jpg  24 Hp Mudmotor Finally Finished-brass-bushing-shaft_3_1.jpg
24 Hp Mudmotor Finally Finished-motor-mount_1_1.jpg  24 Hp Mudmotor Finally Finished-shaft-ujoint-motor_1_1.jpg  24 Hp Mudmotor Finally Finished-ujoint-upper-bearing_1_1.jpg
24 Hp Mudmotor Finally Finished-frame_2_1.jpg  24 Hp Mudmotor Finally Finished-upper-bearing-shaft_1_1.jpg  24 Hp Mudmotor Finally Finished-motor-angle.jpg
24 Hp Mudmotor Finally Finished-motor-angle2.jpg  24 Hp Mudmotor Finally Finished-ready-go_1_1.jpg  24 Hp Mudmotor Finally Finished-ready-go2.jpg
24 Hp Mudmotor Finally Finished-first-run.jpg  24 Hp Mudmotor Finally Finished-cruzin.jpg
Old 05-17-2010, 05:23 AM
Rep: 756 Posts: 3,328
Looks like a great simple setup.
How about grabbing a GPS and giving an idea of performance?
RPM vs speed.
FF
Old 05-17-2010, 06:44 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,357
Looks great.
Hoyt
Old 05-18-2010, 08:00 PM
DO IT IN THE MUD!!!
Rep: 26 Posts: 95
without the cavitation plate i only got up to 8.5 mph (gps) a little heart wrenching. but today i built the cav plate and will weld it on tomorrow so this weekend if i dont have to work it will be test run #2
Old 05-19-2010, 07:44 PM
DO IT IN THE MUD!!!
Rep: 26 Posts: 95
got the cavatation plate on today and took it out. there was no speed increase but the motor handle much much better. you can let go of the tiller and the motor we just sit there in the same place and go. gps speed only 8.5 mph. gonna go back out in a day or so with a friend who has one and do some more tinkering with the cav plate and motor depth.
Old 05-21-2010, 01:31 AM
Erich_870's Avatar
Erich_870 Erich_870 is offline
Rep: 15 Posts: 49
You've got a really good looking motor there.
Where did you get your roller bearings and cups from?
About your top speed of 8.5mph, what size prop are you running? Mud Buddy recommends an 11x10 prop for your 24hp honda.
Erich
Old 05-21-2010, 05:25 PM
DO IT IN THE MUD!!!
Rep: 26 Posts: 95
erich
all bearings and bushing came from a company here in my local town which is called motion industries if you need it they got it. as for the speed issue im still trying out different things. going out this weekend to do some more tinkering. i have a new friend i met the other day at the lake on the first day i took it out and he has a go devil and they are recommended to go on a 16" transom boat mine is 21" i didnt think that this would be a big difference but i think that it is now are talking to my new friend b/c he had his on a higher transom boat and it didnt run very good either. my prop size is 9x6 which is the same size godevil puts on there 24 hp longtail. as for your mudbuddy it is a short tail mud motor correct? if so it has a gear reduction to it which will let you run a larger prop. go devil's new short tail mud motors also run a 11x11 prop on their 24hp. do you happen to know what the gear reduction on your mudbuddy is? i am wanting to try to build one of them this coming winter and that gear reduction info would be a great help.
Old 05-21-2010, 05:34 PM
Erich_870's Avatar
Rep: 15 Posts: 49
Originally Posted by muddin redneck View Post
erich
all bearings and bushing came from a company here in my local town which is called motion industries if you need it they got it. as for the speed issue im still trying out different things. going out this weekend to do some more tinkering. i have a new friend i met the other day at the lake on the first day i took it out and he has a go devil and they are recommended to go on a 16" transom boat mine is 21" i didnt think that this would be a big difference but i think that it is now are talking to my new friend b/c he had his on a higher transom boat and it didnt run very good either. my prop size is 9x6 which is the same size godevil puts on there 24 hp longtail. as for your mudbuddy it is a short tail mud motor correct? if so it has a gear reduction to it which will let you run a larger prop. go devil's new short tail mud motors also run a 11x11 prop on there 24hp. do you happen to know what the gear reduction on your mudbuddy is? i am wanting to try to build one of them this coming winter and that gear reduction info would be a great help.
I don't have a mud motor, but I'd like one some day. You bring up a good point about different props for long and short tail mud motors. Mud Buddy doesn't specifically say which type of mud motor they're talking about in thier prop suggestion guide. http://www.mudbuddy.com/Propeller%20...on%20Guide.htm
You might give them a call just to double check your current prop size.
Erich
Old 05-21-2010, 07:02 PM
DO IT IN THE MUD!!!
Rep: 26 Posts: 95
erich
longtail are direct drive no reduction, shorttails are belt or (gear box like prodive motors) so they have a reduction which lets you turn a bigger prop. i went out a few days ago and i tried an 11x11 prop that i got off of ebay for very cheap and this prop had so wear so it was probable around 10-10 1/2 x 11 and with the direct drice on my motor it will kill the engine when it was set in the water so i took it off not wanting to damage my new motor. as far as prop sizes i go to go devils website b/c they list the prop size for ever motor that they sell. for my speed problem i think i am going to has to lengthen the shaft and tube on my motor so that i have a direct corrilation to the original go devil on a 16" transom boat, so i am looking at about a 94"-100" shaft on my motor to compinsate the difference in height.
Old 05-21-2010, 07:08 PM
Erich_870's Avatar
Rep: 15 Posts: 49
erich
long tail are direct drive no reduction, short tails are belt or (gear box like prodrive motors) so they have a reduction which lets you turn a bigger prop. i went out a few days ago and i tried an 11x11 prop that i got off of eBay for very cheap and this prop had so wear so it was probable around 10-10 1/2 x 11 and with the direct drive on my motor it will kill the engine when it was set in the water so i took it off not wanting to damage my new motor. as far as prop sizes i go to go devils website b/c they list the prop size for ever motor that they sell. for my speed problem i think i am going to has to lengthen the shaft and tube on my motor so that i have a direct correlation to the original go devil on a 16" transom boat, so i am looking at about a 94"-100" shaft on my motor to compensate the difference in height.
I'm familiar with the differences between long and short tails It sounds like your well on your way to figuring out how to improve your performance. I agree that lengthening your shaft to reduce the angle should yield some improvements. Keep us posted
How long is your shaft right now?
Erich
Old 05-21-2010, 07:13 PM
DO IT IN THE MUD!!!
Rep: 26 Posts: 95
the shaft is 72" so 24" or a bit more may be needed
Old 05-21-2010, 07:28 PM
pistnbroke's Avatar
I try
Rep: 387 Posts: 1,269
I think its a well engineerd professional job . Note how you need much extra Iron to brace it all if you go for the direct drive rather than the underslung chain drive system.
Your speed problem is all to do with the prop..your motor has a govener and I suspect its running at governed speed ..say for your motor thats 4000 rpm ...you need to increase prop pitch to get it down to say 3750 or its not at full throttle ..the governer is throttleing it back to 4000. you need a tacho like a tiny tach to see whats going on
You need to get the boat up to about 15 mph to get it on the plane ..dont see why you should not get 25 mph + easy. dont be tempted to take the govener off ..its not more revs you want its more pitch and leave that shaft alone till you get the pitch right .
Old 05-21-2010, 07:53 PM
DO IT IN THE MUD!!!
Rep: 26 Posts: 95
pb,
thanks for the info. i do know that a worn out 11x11 is way to big. a friend of mine has a factory built go devil it has a 24 hp honda on it it same as mine and it uses a 9x6 prop (factory recommended). when i run mine i can tell that the prop is cavitating so i think if i can get that to stop it will go faster any suggestion on that?
Old 05-21-2010, 08:37 PM
pistnbroke's Avatar
I try
your motor is governed to 3600 rpm (honda site) so with a 6 inch prop your max speed with no prop slip is 20.45 mph.....that to me sounds too slow for a 24 hp on a small tin boat......you need to measure the revs and put a prop on the get the revs a little below 3600 at WOT ...your problem is that a prop thats ok at max throttle is too much load at idle...certainly a cavitation plate but is the iron work above and in front of the prop drawing air down?
my 6.5 hp is driving a 10 x10 with a 2.2 reduction..so thats equivalent to a 10x4 if direct drive ...if you got a swimming pool thats a good place to experiment with a bracket on the edge or set something up on the river bank where its deep.
Addition
Looking at it again the shaft does look a bit short.....thats the other advantage of the under slung shaft with a drive chain you can get the shaft right down on the transom
Old 05-24-2010, 07:51 PM
DO IT IN THE MUD!!!
Rep: 26 Posts: 95
i moved the cavitation plate back away from the prop a few inches which increased my speed to a whopping 10 mph. but with the cav plate moved forward the prop the prop rises out of the water will running so i am going to put a wing on the back of the cav plate at about a 45 degree angle up to help push the prop down while running will hopfully be able to test this idea in a few days. if any body has any other ideas on this please let me know im running out of ideas
thanks
Thai Longtail/mudmotor With 6hp Lifan/honda pistnbroke DIY Marinizing 79 06-10-2010 07:11 PM
Online Store is Finally UP and Running gcmdistributor Boat Design 0 02-03-2009 09:05 AM
I finally made it home! Distans 52 Open Discussion: All Things Boats & Boating 21 01-08-2009 07:58 PM
Oh Joy is finally feet dry CharlieCobra Wooden Boat Building and Restoration 0 08-27-2008 08:51 PM
Megayacht Legacy finally free charmc Sailboats 0 02-29-2008 11:58 AM
