| Yanmar YSE-8 I acquired a Yanmar YSE-8 some years ago and am just now impressing into use for a Roberts Spray 27 I've been building off and on for some time. The engine, after a new impeller and injector, seems to run well, and I've heard they're tough. From what I can tell, neither an air nor oil filter exists. Is that of concern, or do you just plan to change oil more often? Any information about this engine would be appreciated. Thanks, Dan |
| I bought an YSE 8 myself some years ago and got a users manual with it (in Swedish). Anyway, it says change motor oil every 100 h and gearbox oil every 250 h. It doesn't have oil filters. It took a lot of work to make the noice from the motor bearable. A one cylinder motor vibrates a lot so you need to put it on soft dampers, add an air intake silencer and an extra silencer for the exhaust. Also build a sound insulating box around it. Having done all that my YSE 8 became rather quiet. The positive side is that it is very reliable and hardly uses any diesel at all when running, 1 - 1.5 liters/h at full power. It would take a lot of abuse to make it stop working. Erik |
| Thanks, Erik! I'll heed your advice on sound dampening. Dan |
| Cummins vs Yanmar | vjb | Diesel Engines | 67 | 03-27-2007 06:56 AM |
| volvo md7a replacement with yanmar 1GM10 | marto | Inboards | 3 | 01-16-2007 09:29 AM |
| Yanmar 4JH3-DTE or 4LHA-DTP for 31' boat? | tomi | Powerboats | 5 | 03-02-2006 01:22 AM |
| yanmar 6lp-stzp 315hp | hilux38 | Propulsion | 3 | 12-07-2004 03:32 AM |
| Yanmar GM Series 1GM10E | Robert Miller | Sailboats | 4 | 07-21-2004 08:31 AM |
