How difficult to find when even a phone line is not available? Grow up, pro´s provide professional service, worldwide. Regards Richard |
| Cost of parts and service is as large as the fuel cost for many Recreational boats. The reason is many fluids and service items are done on time installed , not just hours run. If the anti freeze needs changing every 2 years , weather its 200 hours or 3000 operating time , its the 2 years that the PM is needed. To select an engine I would find out the required maint regime , as well as compare the costs of a rebuild kit , replacement cylinder head or injectors and pump. FF |
| Isn't Yanmar an aluminum block and other iron. Would go with iron because of corrosion issues.... |
| I used two Deutz 1013s with pumps on a large dewatering project a few years back. Very impressive engines. They would make excellent propulsion engines. |
http://www.hs-marine.de/cms/front_content.php?idcat=29 |
My admittedly smaller cummins B3.3 have a definite MADE IN JAPAN badge on them They are a Komatsu based engine. Below is a list of other cummins stuff NOT made in the usa Quote:
| One of the big factors in the noise of a diesel is the fuel injection system. Go for something with a common-rail system if you can, and avoid direction injection if you want a quiet(er) diesel. Most modern diesels now come with an induction silencer - make sure whichever engine you're looking at has a big plastic box / tube on the air intake. This makes a significant difference to the noise. |
| 91 thompson 240 Fisherman stringers and transom | chico312 | Powerboats | 12 | 09-08-2010 04:09 PM |
| Yanmar 240 HP Fuel/Water seperator Filters? | WickedGood | Diesel Engines | 3 | 06-13-2010 06:57 AM |
| 6bta accessory pulley ?? | Reelalure | Diesel Engines | 3 | 03-17-2010 02:51 PM |
| Chris Craft 36 Commander Re-engine to 6BTA | schpere | Stability | 5 | 04-06-2008 12:32 PM |
| Cummins vs Yanmar | vjb | Diesel Engines | 67 | 03-27-2007 05:56 AM |
