Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
  #241
Old 12-14-2009, 03:04 PM
Rep: 700 Posts: 3,208
Marinize a diesel is fast and cheap, IF you do it workboat style.
Keel cooling , dry stack exhaust , best performance , low cost and if you pick a great but less popular engine , its dirt cheap.
International DT 466 or 360 is my first choice for 100-150hp "forever".
FF
  #242
Old 05-10-2010, 10:11 PM
powerabout powerabout is offline
Rep: 432 Posts: 1,359
Just spoke with a mate who is a Yanmar diesel dealler in OZ.
Had a trip through the factory in Japan..very clean he said except the part where the guys are grinding the toyota logo off the blocks!
Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers.....
  #243
Old 05-11-2010, 09:32 AM
capt littlelegs capt littlelegs is offline
Rep: -67 Posts: 237
Bypass filter
Forgive me if this has already been mentioned but I've tried to plough through all the posts. I seems to me that the assumption is that the filter is a conventional full flow type where you would also need a pressure bypass valve.
From what I've read the oil filtration system appears to be a bypass type or a combination that still gives unobstructed full flow direct from the pump in the event of a blocked filter. This is not an unusual design to drain back fully to the sump and also prevent oil spillage when changing the filter.
Changing the filter to a conventional type as a remote may defeat the original design features and possibly cause oil starvation at some time. Whilst I can understand the concern for a slow oil pressure build up, I don't think this is a real problem as the oil may well be circulating instantly but at a lower pressure before the bypass filter fills up and the alarms can be delayed or thrown overboard.
Only a detailed examination of workings of the oil pressure system can tell for sure and should be done before any alterations are carried out. I have a Mercedes engine that has a similar draining filter system without any issues.
Yanmar 6LP upside down oil filters. Frosty Diesel Engines 24 07-16-2009 10:30 AM
High Oil Pressure 4.3 Carb Mercruiser Stingray359 Gas Engines 4 04-26-2009 10:49 AM
Volvo Oil Pressure problem crackerjack Gas Engines 3 04-24-2008 01:25 AM
Diesel Oil Pressure Query darrenyorston Diesel Engines 3 11-25-2006 08:39 PM
Cold Molded Construction & Long Term Value fishboat Powerboats 2 06-03-2003 04:02 PM
