Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
  #151
Old 09-21-2009, 06:19 AM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1930 Posts: 4,195
Most of the auto sump pumps have a shaft you drive them on. Chevy makes such a thing... Phone a spares shop and ask. I'm sure Thailand must have spares shops too ?
Ive racked my brains thinking of an outomotive application
What brains ????
Regards
Fanie
Water ! Just gimme water !
  #152
Old 09-21-2009, 06:32 AM
masalai masalai is offline
masalai
Rep: 1630 Posts: 7,322
It is not for a motor-bike, that is all.... (Probably explains why the boat hardly ever moves)
Try to be helpful... The trouble with people is to realise and remember that there are at least two sides for every story...
A woman's breasts, one is not enough, - two may be just right, - but dreaming of 3 is a pleasant fantasy...
  #153
Old 09-21-2009, 08:03 AM
powerabout powerabout is offline
Rep: 432 Posts: 1,358
The pump is going to need a but of grunt and will need to be a gear pump.
If you have ever put a hand drilll on the shaft of a engine oil pump and tried to pump oil you will see.
I think the cold oil will be the problem being so viscious.
I think Johnson pumps makes a fibre grear gear pump for fuel transfer?
A fuel pump from a Detroit would be about the right pump....
Just need the motor and drive
Some of the larger freshwater pumps kits are also gear pumps.
Perhaps google fuel polishing as many are gear pumps
http://www.depcopump.com/catalog110/041.pdf
I was going to suggest a trim pump from outboard or sterndrive ( once you adjust the pressure out) but not sure how they will work without a flooded inlet as they operate in their own reservoir.
Late Merc high vol low pressure would have about the right flow and an all in one package.
They were designed to use 10w engine oil.
Best of luck.
Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers.....
  #154
Old 09-21-2009, 12:27 PM
scotch&water scotch&water is offline
Rep: 51 Posts: 46
Pumping Oil
Hi Frosty My thinking is that the lift pump on out drive lift cyl. would work, with a check valve and pressure sender for an electric guage would be a good ad on, for the sump a section of pipe with a plate top and botom some fab. work to connect the pump, it could get oil feed fom the oil cooler? Fritz.
  #155
Old 09-21-2009, 10:48 PM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1514 Posts: 5,518
I have investigated the trim and tilt pump off an old outboard. A new one is cough --splutter--expensive,--- and I need 2.
I could fly to America and buy a Tilton cheaper.
I am proud of my engine installations in my white engine rooms , I don't want a cocked up pump and motor bolted to them. I want a nice neat installation. These Yanmars are complicated enough with alarms and bells,I really don't want to make it more so.
Spares shops are every 200yds --literally-- but if Toyota Isuzu or Mitsubishi dont use them , then they wont have them.
I will change tactics and investigate the 4 wheel drive race shops.
  #156
Old 09-22-2009, 01:25 AM
pistnbroke's Avatar
I try
Rep: 372 Posts: 1,230
I beleive in KISS so as the main problem is that he oil filter is UP rther then DOWN the the solution is the turn the filter ...adaptor or remote ...??? Of course if we had photo of these operating theatre style engine rooms we might be able to help a bit more ...ha ha if you need anything from au or uk I can get it posted to you .......
Stay cool but not too Frosty !!!
  #157
Old 09-22-2009, 04:36 AM
Frosty's Avatar
You asked the same question or made the same remark some time back. I wrote a lengthy reply as to why this is not possible.
  #158
Old 09-22-2009, 08:50 PM
WestVanHan's Avatar
WestVanHan WestVanHan is offline
Not a "Senior" Member
Rep: 352 Posts: 550
Frosty also check out Mocal oil pumps like this,same price as Tilton:
http://www.racerpartswholesale.com/p...al_Cooler_Pump
  #159
Old 09-22-2009, 11:45 PM
Frosty's Avatar
Again ---perfect --just what I want.
Postage will be 200 dollar ,--if they can or will take a mastercard.
And no tracking number or insurance. It just wont get here.
Been here so many times
  #160
Old 09-23-2009, 12:05 AM
masalai
Frosty, F... ameri.... have you tried to get it from ozzi? we have registered and insured small package delivery with signature required through Australia Post or even some couriers? - find the place and product (preferably Brisbane)... I will look around... and see what I can do...
I will need size LxWxH and if it meeds "bubblewrap protection" and weight and value for insurance - aren't those septic businesses useless....?
  #161
Old 09-23-2009, 12:17 AM
mark775
Frosty, I have the same problem getting stuff past customs into Mexico. One method is to get someone you trust to bring it. Even a random unknown traveler would be more reliable than customs with nobody watching. Bags are often light going over so that they can be filled for the trip back... Maybe even someone on this forum is traveling there soon.
  #162
Old 09-23-2009, 12:20 AM
mark775
Mas, Fine. Why do always have to be a dick?
  #163
Old 09-23-2009, 12:27 AM
masalai
For F's sake the man has explained the difficulties with trying to do business with USA several times... Over-priced will not accept mastercard, and do not deliver - so who is the dick? - - I usually call a spade a spade, and an idiot gets the response deserved, for an inane and stupid question... - - - - I stayed out of the play because it is not my field, and no forthcoming, helpful, or, useful suggestions to supply? - - - **** I am no expert but given the stuff from Frosty, I reckon any dumbarse could deliver so all the dumbarses over there could not - so it seems? - - At least I will have a go...
  #164
Old 09-23-2009, 12:40 AM
WestVanHan's Avatar
Rep: 352 Posts: 550
OK Frosty this is it....
I have had import businesses and still import "samples" for fun.
Co.s usually have minimum orders,tell them u want to buy a few for testing, when you just want them 4 spares.
Made in Thailand,not heat rated (need check valves) and you can run the pressure down to 1 bar.
http://www.alibaba.com/product/th101...mp_TG_BS5.html
TOPSFLO PUMP TECHNOLOGY CO LTD
Street Address: Nong Phalai Banglamung
City: Chonburi
Province/State: Thailand
Country/Region: Thailand
Zip: 20150
Telephone: 66-3-62788985
Fax: 66-3-62736895
  #165
Old 09-23-2009, 12:47 AM
masalai
Good on the Canadians, Thanks Sir... and later maybe? as... " You must spread some Reputation around before giving it to WestVanHan again. "
Yanmar 6LP upside down oil filters. Frosty Diesel Engines 24 07-16-2009 10:30 AM
High Oil Pressure 4.3 Carb Mercruiser Stingray359 Gas Engines 4 04-26-2009 10:49 AM
Volvo Oil Pressure problem crackerjack Gas Engines 3 04-24-2008 01:25 AM
Diesel Oil Pressure Query darrenyorston Diesel Engines 3 11-25-2006 08:39 PM
Cold Molded Construction & Long Term Value fishboat Powerboats 2 06-03-2003 04:02 PM
