| Yanmar 6LP upside down oil filters. I have 2 Yanmar 6LP. From the day they were new it took the oil pressure 7-10 seconds to shut the alarms. I contacted Yanmar Australia who said it is not a problem because 2 engines can not have the same problem,(oh great dignosis technique) Further communication resulted in them telling me to get a life. I love the Aussies. The engines were also poorly panted with bolts missing holding the intercooler to the block. Never mind move on. So I investigated myself and I found that the upside down filters drained. Same day starting was Ok ,leave it over night and it was like an oil change needing 7-10 seconds to prime the filter, actually the filter could be spun off and nothing there. These filters are face down (upside down) so any failure in the built in anti drain valve allowed oil to drain back to the sump. Problem found but not solved. Yanmar insists on genuine Yanmar filters, I forget how much they were but I fell over. If you wipe the paint of it says Toyota as the 6LP is the Toyota 1hd engine from the Toyota Landcruiser. I have sawn many filters in half looking for good ones and they "all" drain back, not through the drain valve but through spot welds under the rubber seal flange!!!! spot welds??? how can spot welds seal? So I don't like upside down filters. Yanmar don't think its a prob and Toyota dont seem to know about it. 7 seconds don't seem much but if you use the boat just once per day, after 9 month the engine has ran for 1/2an hour without oil pressure. There is an answer--a remote oil filter kit that mounts a regular filter the right way up, trouble is no one does a 24 x1.5 thread kit! Any 6 LP owners here? |
| Yes, 7 sec seems a bit long time, but there are other engines with "bowl-up" filters, for instance Iveco´s. And when you have to switch filters in a crowded engine space, I love the empty bowls; there is no spill, ever. But still, your time to build working pressure, sounds weird. It might be a pressure control valve that is not closing fully, meaning that some oil is returned directly to the pan. With the system empty, this could lead to excessive evacuation time. |
| Yes some engines do have a check valve to hold the filter full. Both engines identical problem? The Yanmar 6LP rely solely on the anti drain valve which don't work. The Toyota 1HD guys are screaming out for a M24 x 1.5 remote kit. Ever made one? shouldnt be difficult to make one from the base plate of an old filter, then buy a duel filter. |
| Frosty, Anyone with a metric screw cutting lather(prob'ly the only kind you'll find over there ), or even an English lathe with the proper translating gears can cut this thread for you with no problem. That nut would take an experienced machine operator no more than an hour to make as it's just a tube with a cut down area that's threaded. Very simple. If you start with square or hexagonal bar stock (very common stuff, either one) then you'll be able to turn it with a wrench later.You already know where I'm going with this: Buy a remote filter adapter! If you get a batch of the nuts made, you can sell the kit yourself and make a few dollars or pounds or whatever you get paid in over there ![]() Jimbo |
| But??? Firstly you would need to machine and thread the filter converter take off to take an adapter to convert 24mm to say 28 to screw into the adapter. I don't understand what the "nut "is for? |
| I will be facing a similar exercise for my little kubota 3 cyl 21 hp genset which should arrive in a week, I will post the info on my build thread when and as... If you find a solution sooner please let me know...
__________________ Try to be helpful... The trouble with people is to realise and remember that there are at least two sides for every story... A woman's breasts, one is not enough, - two may be just right, - but dreaming of 3 is a pleasant fantasy... |
| Sandwich adapters have no threads, Frosty. The whole trick is in the nut. The nut holds the thing on, carries the oil and secures the filter later. The adapter just has a smooth bored clearance hole that the nut passes right through. You should be able to take a sandwich adapter that fits diametrically and just get a nut machined to fit the oddball thread on your engine or filter. The adapters I showed you earlier from Flex-a-Lite (I believe that was the one) were this style, with a smooth bore clearance hole. Jimbo |
| Would you mind either showing that again or directing me to where I could see it. I'm a picture guy. For me a picture might be worth 2000 words. ![]() Thanks
__________________ If this is tourist season, why can't we shoot them? |
| Ok ive seen the sandwich adapter on the Flex o lite web site. I would have to make a plate to simulate the filter to blank the top of the adapter off. |
| All googling Flex o lite gives me is flexible sheets and glass reflective beads, anyone got the link for the oil filter adaptor?
| Here they are right here; http://www.flex-a-lite.com/auto/html...-adapters.html Notice the smooth bore in the adapter casting with no threads. The nut threads over the existing threaded nipple to secure the adapter to the engine. Yes a flat plate would be needed to make this a remote adapter, but I bet with a little more searching we could find one already built that way. Jimbo |
| Look, I found some: http://www.livermoreperformance.com/..._adapters.html Scroll down to see the bypass style adapter that has a nut instead of a nipple and seal surface. It's as if they took a sandwich adapter and installed the flat plate for you so you won't need to bother with that part. That is the one you want. All you will have to do is get the proper nut made at a machine shop. You may also need to bore the clearance hole for the nut larger as you nut is larger in diameter. Not rocket science, though. Jimbo |
| Thanks Jimbo1490 - - "You must spread some Reputation around before giving it to Jimbo1490 again." - - I tried ![]() ![]()
| Thanks Jimbo, It all becomes clear with a picture! ![]()
| See those filter plates right at the bottom? well thats basically what you have in the filter, pretty well much the same, only steel. Take one of those and weld a pipe on the hole of the centre of the plate. Then weld a 4 inch pipe,--- say 1 inch deep onto the outside of the pate. Make a flat plate that goes over the the top of the pipe you have just welded on with the center pipe coming out of the middle. Weld all that up and you have an adapter. You then drill and weld a fitting on the outer pipe almost next to the inlet pipe. Oil adapter finished. This is my plan, steam pipe and fittings from the plumbers shop. |
| Pair Yanmar 6LP-STE 300HP New Rebuild Option Outdrive | marinediesels | Marketplace | 1 | 06-11-2009 02:32 AM |
| Upside down | arthor | Fiberglass and Composite Boat Building | 2 | 05-21-2008 11:44 AM |
| Screw on oil filters (VolvoMD2 engine) | peter.mills | Diesel Engines | 2 | 09-14-2006 11:08 AM |
| Getting it upside down?? | Ralphw | Wooden Boat Building and Restoration | 1 | 08-02-2005 01:07 AM |
| yanmar 6lp-stzp 315hp | hilux38 | Propulsion | 3 | 12-07-2004 03:32 AM |
